    Results 41 to 60 of 61
    1. #41
      New Jersey
      I'll check my notes and get back to you. Thanks
      Camaro Convertible Build Pics - http://s447.photobucket.com/albums/qq198/rob07002/
      www.musclerides.com
      Rob Stevens
    2. #42
      Castro Valley, CA
      Quote Originally Posted by killer69 View Post
      we have been talking to Stainless works about this ........................ your using a LS?
      Yes LS3
      Quote Originally Posted by LM7_67 View Post
      how's header fitment? will headers designed for a stock subframe fit? or is it strictly the SW headers?
      Your stuck using SW 1 3/4 as my post said. No other options
      John S.
      68 "Bloodline" Camaro in assembly...
      Speedtech Sub, Alston G-Billet/Fab 9 rear, Ridetech coil overs, Moser axles, Fesler 19's, Lots of Anvil parts,Twin tubo LS3/T56, Carbon fiber manifold, and the list goes on and on..........
    3. #43
      Mar 2010
      Tempe, AZ
      we have tried a couple different brands, and all the ones we tried needed the 3 joint shaft and some even with that needed a tube changed, THE BEST fit and option is th e stainless works headers. they let you use a 2 joint steering shaft and also give the most ground clearance, we designed them to sit as high in the sub as is possible unlike ALL the headers we tried which were designed prior to lowering springs!!! our BB headers sit 1.8" higher than the hooker super comp headers. small block headers are only 14 below the frame rail
      Hm, I have the 1 7/8" ARH LS headers in my stock sub and the fit and ground clearance are fantastic. Thinking about your subframe, but I would love to be able to keep using these headers.
      1967 Camaro - LM7, T56, TVS, 12.7:1
      1996 Impala SS - DD
    4. #44
      St George Utah
      All i can tell you is that you "MAY" have to modify the #1 cylinder tube to fit the steering column. i would suggest making the changes to the headers to run a 2 joint steering shaft rather than using the 3 joint shaft and keeping your headers.
      Blake Foster
      www.speedtechperformance.com
      435-628-4300
      St. George Utah.
      it's always sunny here.
    5. #45
      New Jersey
      Rob where do you have the alignment set now?
      I pretty much went with the Unisteer specs.
      Toe: 1/16"
      Camber: 1/4 degree positive
      Caster: 1.5 degree positive
      www.musclerides.com
      Rob Stevens
    6. #46
      St George Utah
      Quote Originally Posted by rob07002 View Post
      Toe: 1/16"
      for an agressive street, mild autoX setting try
      toe is probably ok
      Camber -3/4
      caster +4.5 -5
      that will be better.
      MAKE SURE THE GUY DOING THE ALIGNMENT KONOW WHAT HE IS DOING!!!!
      seems most guys that use the fancy machines have no real idea what they are even doing,
      They punch in the car and the machine can only tell them what the factory setting is.............. like your specs that look pretty close to factory.
      if you can find a race shop espesially a road raceshop that will do the alignment
      Blake Foster
      435-628-4300
      St. George Utah.
    7. #47
      Dec 2010
      Fredericksburg, VA.
      Blake,
      Does the complete subframe include spindles? I was reading the product page and it does not specifically say.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
    8. #48
      St George Utah
      No it does not include spindles, we can get you new ones if you want, but if your not going to go with the AFX spindle then we suggest you reuse your existing spindles.
      Blake Foster
      435-628-4300
      St. George Utah.
    9. #49
      NJ
      Toe: 1/16"
      Where in NJ are you. I align these things all the time
    10. #50
      San Antonio, Tx
      that explains why when i bought the speed tech sub frame from jegs it came with their brand spindles.
      Instagram: CamaroAJ
    11. #51
      NJ
      Quote Originally Posted by CamaroAJ View Post
      was it cheaper in Jegs
    12. #52
      May 2009
      Florida
      Shipping is cheaper
      Fernando
      1967 PT Camaro
      Project "N-XSS"
      https://www.pro-touring.com/forum/sh...ad.php?t=70712
    13. #53
      San Antonio, Tx
      Quote Originally Posted by TBART70 View Post
      jegs had it mispriced so it was below their cost. so i bought it since it was in stock. also i live 4 miles from one of their stores so i didn't have to pay shipping.
      Instagram: CamaroAJ
    14. #54
      NJ
      cool
    15. #55
      St George Utah
      i Remember that You Really Scored!!!
      but i had no idea they were selling it With spindles????
      good deal then.
      we are currently working with a shipping company to try and reduce the shipping cost.... we will see how that goes, right now i think we are about one of the most rrasonable on shipping??
      Blake Foster
      435-628-4300
      St. George Utah.
    16. #56
      San Antonio, Tx
      it was a good deal since they were disk brake spindles that i need to sell since i ordered the tall ATS spindles from you.
      they only thing jegs doesn't give you the option of is motor mounts. it comes with small block mounts only and it also doesn't come with sway bar end links.
      Instagram: CamaroAJ
    17. #57
      St George Utah
      Actually NOW when you order from Jegs you will get both LS and SB/BB motor mounts it was to hard for them to manage the multiple options. also the sway bar end links come in the subframe hardware package. they used to be included in the lower control arms.
      So it sounds like your all set up!!
      Blake Foster
      435-628-4300
      St. George Utah.
    18. #58
      San Antonio, Tx
      i couldn't use the motor mounts anyway since i moved the engine back 7". once i get far enough in the build i'll have to call and order a set of end links from you guys since i didn't get them from jegs.
      Instagram: CamaroAJ
    19. #59
      New Jersey
      toe is probably ok
      Camber -3/4
      caster +4.5 -5
      Thanks Blake. I'll give this a try.
      www.musclerides.com
      Rob Stevens
    20. #60
      New Jersey
      I'm in Old Bridge
      www.musclerides.com
      Rob Stevens
