      So. Cal.
      Still running really cold
      I think I posted here about my engine running too cold and thought I had it worked out. NOT!!
      Went for a putt today, it was 75* outside. I was driving at around 55mph for about 20 miles. The engine was as warm as it was gonna get and it was only at 153*. WAY too cold. And I have two sensors. One for my gauge and the other for the EFI computer, they both agree, its 153.
      I want the engine (water temps) up around 185-190*.
      I have a 185* stat in and it seems to work with the simple checking I have done. You know, idling the engine up to temp with the radiator cap off looking for the opening of the stat with an inrush of coolant. And I saw that. I can idle it up to 185*, the stat will open and close. I can see that with the coolant flow with the radiator cap off.
      And idleing through town I can get some nice heat. It will peg at 185* and stay there. I like that.
      But if I go any faster than 30mph she cools WAY down, not "cool".
      Id actually like to see 195-200* with my EFI mill. She runs SO much better with a lil heat.
      I have the electric fan controller set to max temp. I dont even think the fan is turning on with any speed above 40mph. Its just too cold. And the outside temp isnt very cold. 75* is not really cold, its perfect.
      So my question? How can I get more heat!!
      Any help would be great. Im running around with a cold engine that is sucking up fuel and basically in hibernation due to the temps. I need to heat things up a bit. JR
      What I write is opinion, none of it is factual. 2010
      Even though I'm conscious it doesn't mean I'm coherent. 2011
      I'm getting better with age. Best thing about old age is I don't know any better. 2012
      Ramona, Ca. San Diego area
      move to Phoenix. LOL J/K
      that's a strange problem you have there. Maybe try a different stat. Maybe the one you have is defective???
      67 Camaro convertible (Jinx)
      So. Cal.
      Quote Originally Posted by 67 ls1 vert View Post
      Yup, thanks. Thats the road Im going with, a bad stat. I just wanted to get some other views before I went there. I think you are correct. JR
