      Aug 2009
      Langley BC, Canada
      Best Ignition for my needs??????
      I have a sbc 383ci in my Impala and I am thinking of stepping up my ignition. Here is what I am working with now.........
      383ci sbc
      AFR Eliminator 195cc street heads
      230* int 236* exh duration @.050 and .510 int and .520 exh lift
      Speed Demon 750 with vac secondaries
      2 1/2 exhaust with block huggers
      air gap dual plane intake
      Proform? HEI ignition with new petronix coil and module
      700r4 with a 3100 rpm Edge converter
      9" with 3.89 gears and 27 " tires
      The car is 99% street driven and was wondering if it is worth stepping up the ignition to a box or something? If so what one?
      Kevin Freund
      1961 Impala Drop Top
      Aug 2009
      Langley BC, Canada
      Kevin Freund
      Mar 2010
      Alabama
      Im not expert but I know that an MSD 6al would probably help and would be probably cheapest and easiest route to go.
      David Butler
      "If you're not first, you're last"
      67 Camaro Twin Turbo SBC (changing from Blow-thru to Holley HP EFI)
      Aug 2008
      Houston, TX
      I'm using an MSD 6AL-2 right now, have had it for 2 years now without any reliability issues. It even survived THIS accident and still works like a champ. My Camaro is 99% street driven; the box definitely helps. Cold starts are literally a half second turn of the starter and she's running. Cruise and idle are smooth. I would definitely recommend it.
      P.S. My engine combination is VERY similar to yours.
      Who is wise? One who learns from every man... Who is strong? One who overpowers his inclinations... Who is rich? One who is satisfied with his lot... Who is honorable? One who honors his fellows" - Ben Zoma, Ethics of the Fathers, 4:1
      Aug 2009
      Langley BC, Canada
      Thanks for the input guys!! What distributor are you running? Vac advance still? Also what coil?
      Kevin Freund
