      Oshawa ON
      Leaf Spring Perches Question
      I am completing a mini-tub on a 69. I have a 9" with Hoctkis leafs that I am using.
      The questions I have are "what perches do I use? Do I use the original style perches or can I use a flat (Ford, Mopar) style perch? Does one have an advatage over the other?
      I noticed the DSE perches are a flat style that bolt on. I think the multileaf would be the strongest.
      May 2002
      Northern California
      Depending on the spring method and axle housing you use a stock one might not fit. You can use a universal or a DSE one. Advantages....the DSE one bolt locks, you can adjust later...stock style welds on.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Oshawa ON
      So which one is the best?
      May 2002
      Northern California
      Can't say which is best, thats a matter of opinion and well...I use the DSE ones.
