Results 1 to 20 of 27
Thread: Project Getaway
- Dec 2007
- 14
Well the reason is I wanted it to fill the fender well opening. A 18 would do it fine but you would need to use a tire that wouldn't have close to the same aspect ratio of the rear. I fell it wouldn't look right with a lower profile tire in the rear then the front. Both front and rear of the car have almost the exact amount of sidewall showing and I think that helps balance the car out. Most people put the rake into the stance of the car by raising or lowering the front or rear. My car sits dead level on all 4 corners and the rake was put into the body when it was mounted to the chassis. This should help with how it will perform. Thanks
