Results 1 to 1 of 1
Thread: The Challenge for TODAY:
01-25-2011 #1
Starting The Transformation
- Sep 2010
- 188
Tuesday : January 25th : Holley
Holley will be giving away an EFI HI-RAM STYLE INTAKE to the winner of the challenge on day 2.
PLAY VIDEO TO SEE THE CHALLENGE
For use with LS-series engines with LS3/L92 heads, this cast aluminum intake manifold has been designed as a cost effective alternative to fabricated sheet-metal intakes.
Designed using Computational Flow Dynamics (CFD) analysis, this new intake manifold features optimized equal length intake runners, and is intended for use on both N/A and forced induction applications in the 6.0-7.0 liter displacement range. The Holley Modular Hi-Ram LS intake develops maximum power between 7,000 and 8,000 rpm and can be used on a wide variety of street or race engines.
Thanks to its new modular design, the EFI Hi-Ram is designed to accept a wide variety of Holleys carbureted, EFI, and blank tops to offer builders and fabricators an optimal foundation for custom induction systems. On fuel injected applications the system comes with black anodized -8 fuel rails, which are large enough to accommodate high flow fuels and dampen pressure pulsations as well.
The intake can be mounted in a forward or backward position and is suitable for use in a wide range of applications including drag race, muscle car, marine, off-road, street-rods, and more.
Product Dimensions:
- Total Height for 2x4V Tops & Blank Top 11.08 from the lifter valley cover flange on engine block.
- Total Height for 92/102mm EFI Plenum Tops 12.32 from the lifter valley cover flange on engine block.
- Port Size 2.49 Height x 1.21 Wide
- Cylinder Head Mounting Flange Gasket Type 3/32 Round O-ring cord
- Plenum Top Gasket Type 3/32 Round O-ring cord
- Runner Length 6.50, As-Cast Runner Cross-Sectional Area Tapered 4.25 to 2.77 in²
Be sure to check out all the great products at*Holley.comLast edited by Road Tour Express; 01-25-2011 at 07:34 AM.
