Results 1 to 10 of 10
Purchasing Undeveloped Land: QUESTIONS
I have never purchased "land" with nothing on it. I found some locally for what I feel is a really good price, and am definatley interested in it for future investment or building opportinities.
What do I need to know?
Is there good/bad to this idea?
What questions should I ask?
I went and viewed the area today, and will check it out again tomorrow in better lighting but I figured I would ask up for those who may know more than I can think of to ask.
Thanks!
-jake
MY '69 DATSUN 521 PROJECT:
https://www.pro-touring.com/showthread.php?55660
MY '71 MONTE CARLO:
https://www.pro-touring.com/showthread.php?58557
01-23-2011 #2I found this and used this so far but any additional would be great!
10 Questions to Ask When Evaluating Land
1. Has the land been surveyed?
A proper survey is critical to any land purchase. Be sure it includes an exact identity of all lot corners and survey pin locations.
2. Are there protective covenants in place? What are they?
Protective covenants outline what can be done with the land that surrounds the homesite you’re considering. They are important protections to help maintain the quality and value of your property.
3. How is water supplied?
Water supplies vary greatly. Find out if you have to provide your own well or water supply, or if you can tap into a city/county/township supply.
4. Is there physical access to the land?
Be sure the land has good access to it with roads that have adequate clearance and support for contractor vehicles.
5. Is there legal access to the land?
Be sure that the easements allow clear, legal access to the land.
6. Who maintains the roads?
Find out who is responsible for maintaining upkeep of roads that lead to the land. Some roads are maintained by counties, others are maintained by private landowners.
7. Is the land approved for a septic system?
Costs of septic systems can vary depending on soil type. Be sure soil tests have been run in the area to determine the composition of the soil, and find out what type of septic system can be put on the lot you’re considering.
8. Are you able to build on the property?
If you plan to build, request a guarantee of buildability from the seller before buying.
9. Is the title clear?
A clear title confirms that the selling party has clear and legal right to sell it and provides information critical in the purchase decision. Always ask if title insurance is provided before entering into the purchase process.
10. Is power available?
If you require power, ensure it’s there before you buy, or know in advance the cost to provide it
http://www.naterraland.com/10_questions.aspMY '69 DATSUN 521 PROJECT:
MY '71 MONTE CARLO:
01-23-2011 #3I have some experience purchasing investment real estate, although never bare land as it provides no income while it sits there (doesn't make it a bad investment). One of the many things I've learned so far is the value of a knowledgeable attorney. My last deal was a seller financed deal and without the attorney I would have gotten the short end of the stick. Believe me it's money well spent and you will get quite an education to use in the future as well.
Also, real estate is usually "cheap" for a reason but lots of people are in trouble right now and banks hold a lot of stuff they want off the books so you never know in these times. Do your due diligence and make sure you know why the price is low. Sometimes a better investment is something on the more expensive end of the spectrum. All things need to be considered.
Good luck and I'll be interested to read about how you make out.Erik
https://www.pro-touring.com/showthre...without-a-name
Camaro LS2, T56, 12 bolt, C6 Z06 brakes, Rushforth Super Spokes, ATS Spindles
2006 Chevy Trailblazer SS
01-25-2011 #4Absolutely the first thing to check is the current zoning/allowable land use to be sure you can build what you want. A zoning change can be expensive should the surrounding owners or even the municipality opposes your proposed use.
Everything Jake616 said is correct. You should be able to go into the municipality's engineering/planning department to view all the zoning and infrastructure maps for the area to see what you've got to work with as far as water, sewer, storm drainage, zoning, etc. Depending on the municipalty, you may even be able to view some of the data online. Just make sure you go in to view the most up to date information, as sometimes the online info can be a little out of date.Dean P.
'72 Buick Sun Coupe GSX
My build thread: https://www.pro-touring.com/showthre...ck)&highlight=
01-25-2011 #5
- Mar 2010
- Costa Mesa, CA
- 29
The real absolute first thing to check is for the presence of any HazMat or other polution. The second you are in the title chain of ownership on land, you become liable for potential clean-up!
1967 Pontiac GTO Convertable - early on full resto!
01-25-2011 #6
