Thread: Power Steering problems
01-22-2011 #1
New to Pro-Touring
- May 2008
- 16
I have an just installed a new AGR steering box and pump with all new lines.
Bled everything per AGR instructions.
The pump is working and no noises or bubbles and a full stream coming back from the return line.
Everything seems fine except I have no power steering at all.
Any ideas on what could be wrong?
01-24-2011 #2
New to Pro-Touring
- May 2008
- 16
AGR thinks the flow control valve in the pump is in upside down.. We'll see in a couple of days.
01-24-2011 #3I put in a new AGR pump and it only works when cold. As soon as it warms up I have manual steering. My brother bought one at autozone and his works great. I had mine all tore apart to check the flow valve and it was fine.
01-24-2011 #4PLEASE dont tell me this guys!!! I have a new AGR box and pump! Hope I have better luck... (fingers crossed)
-SeanMy 1973 Chevelle "Bad Buzz" build: https://www.pro-touring.com/showthre...velle-PT-Build
01-27-2011 #5
New to Pro-Touring
- May 2008
- 16
Took the pump apart and found the problem, the pump was full of sandblast sand. No fault of AGR, it was from when the tank was powercoated.
Got a pump from AutoZone and everything is fine now.
