    Results 1 to 20 of 20
      beaverton oregon
      first gen fender flares
      well, some of you may already know the direction i am trying to head with my 67. got a set of flares designed for a 350z. after trimming, eyeballing and alot of head scratching, decided the dam things are gonna take way too much modification to make work. i will spend more time blending them than making my own, so hence the thread.
      got the plan worked out. thought some might be interested to see the process. the rear flares i got i may still be able to use in some form, but fronts no. not sure i will be building out the sides of the car. starting with flares then see what i have.
      squint eyes hard and you can see the direction i am trying to go. progress will be somewhat slow as i don't have alot of time. here is a couple pics with the 350z flares.
      Scott R. (vinny)
      misha widebody SL55 highly modded
      -67 camaro ttls/viper t56, 350z irs, full frame, in the works
      -porsche cayenne turbo 175hp added over stock
      -other crap that just hauls me around!
      Jun 2009
      Piqua, Oh
      I like the concept. Is that where you want the rear wheels to end up ?
      Mike South
      1968 Camaro SS/RS LS1/T56
      Ride Tech Tru Turn, Ride Tech T/Q Coil-overs
      Ride Tech 4-link
      beaverton oregon
      Quote Originally Posted by BuzzKillian View Post
      ya. the rears are 20x13. i always thought the 67's looked to narrow and high. this is my cure for that, haha. even with these flares just taped on the car, i can stand back about 50-60ft and really get a feel for it. nothing like it i have seen!!
      Scott R. (vinny)
      Long Beach, Ca
      I am struggling with the same thing Scott, although I should only need 1.5" front/2" rear flares. I am planning on making the molds out of some high density foam. What are you planning to use?
      Jon Rasmussen
      Ex Team OLJ.
      '72 Nova
      beaverton oregon
      Quote Originally Posted by Nessumsar View Post
      hey john. guessing you got those spacers alright?
      doing an old speaker box building trick. making a plastic ring that will screw to the fenders trapping speaker grill cloth. then a 1/2" particle board front that will create the outer lip/edge of the flare. put a bunch of screws in the particle board and just stretch the material over both. hard to explain, but you can make compound curves this way very easy and your forming is pretty simple too. very easy to make left and right sides identical.
      i just got off the phone with a sheetmetal shop i use alot and they can bend up my side pods out of metal. think i will need to do that first and then i can blend the flares to them easily. the exhaust will be coming through them, so it will probably be aluminum.side pods will be removable, i can make the flares removable also without much work. i do kind of like the bolted on look. looks a little more raw. a strip of double sided tape between will seal it. front spoiler will be just bent up aluminum (exact style tbd) with adjusting rods. some kind of rear diffuser also. gas tank going in trunk, or half in, half out. give alot of room to put rear diffuser at correct angle.
      been drinking beer all day, so my creative juices started flowing, ahhahah
      Scott R. (vinny)
      Long Beach, Ca
      Quote Originally Posted by overZealous1 View Post
      I'm pickin up what you're throwing down. Sounds like a really easy way to do it... Might have to try that.
      And I did get the adaptors, sorry for not letting you know. Thanks.
      Jon Rasmussen
      Ex Team OLJ.
      '72 Nova
      Atlanta GA
      you should wait a minute.. i will be offering a set you just might like.. already made for a 67.
      beaverton oregon
      pics?
      Scott R. (vinny)
      California
      Very interested in seeing how this turns out. Just please don't make massive sideskirts to join the front and rear flares. Just judging by the pics, I can't see sideskirts looking all that good on a muscle car.
      Matt
      beaverton oregon
      Quote Originally Posted by DarkoNova View Post
      there is a reason i have this screen name. one thing leads to another and just can't do it half assed if you're gonna do it.
      the flares were designed for another car. so the ends in the pics would need heavy modification to flow. i am in a situation right now of deciding if i want to wrap up 6 months of extra time in body fab. this type of build needs to happen though. the stumble is how to make the sides flow into the front and rear. forget about the pics above. they are just a slight vision. but, if the flares stop at body height, well then, i just made another eyebrow flared 67. will it have side skirts that flow front to rear? yup! question is, how far to carry them up? to widen a car in the door area takes a ton of work.
      i looked over at my viper, and the side skirts on that run full length with the front fenders (hood) and rear fenders dying into it. so new plan is that. i will keep posting pics as i go and i'm sure nobody will hold back letting me know if it is looking like ****!! hahaa
      Scott R. (vinny)
      san diego
      I want to see how this ends up. I hope it turns out nice.
      California
      Definitely post pics of the progress, then, because I have no idea what you were talking about with the "old speaker box trick," lol.
      Matt
      beaverton oregon
      it is mostly just a way of making forms for fiberglass is all. not sure what the process is called actually, but it is widely used in making speaker boxes with compound curves quick and easy.
      Scott R. (vinny)
      Birmingham, Michigan
      updates?
      1979 firebird!
      That first picture kinda looks like Tito's Camaro in bare metal MANY years ago with its flares and boxed rockers way back when he first started his Camaro project.
      Tito! How about an update on your car also???
      Mike
      www.musclecardeals.com
      beaverton oregon
      plans have changed a little. after starting on the flares i was getting a little worried about how outlandish it may end up. still flaring it, but not to that extent. found a complete 350Z rear suspension and deciding to use that. it will change my track width inward, so the rears will not need to be flared as much, and requiring mini tubs. going to get new rear fender skins and bubble them the 2" i need. fronts will get pulled back in also, but will still need to modify fender and notch front subframe. oh well, getting the complete 350Z rear for that price, will save me about $1500 over doing a solid axle in the long run even getting bigger brakes for it and will be much happier with ride and handling when done. fab is free!! haha
      Scott R. (vinny)
      Oct 2011
      Phoenix AZ
      Damm, you Scott......I was wringing my hands for the out landishnessness....lol. Regardless Im sure the alternative route will be pretty good as well...keep us posted.
      beaverton oregon
      lol. i'm sure you have seen it before, you see a guys car and see how it sounded good on paper but got lost somewhere in execution. i didn't want to be that guy! hahhaa. spend a year doing bodywork with blinders on and then pull it out and want to cry or having people throw rocks at it. lol. it will still be flared, but only half as much as i was imagining.
      Scott R. (vinny)
      Aug 2008
      ocala fl
      Country Flag: Wales
      How about track rat you guys didn’t like these, maybe there not big enough take a look. http://www.camaroperformers.com/proj...ing/index.html
      ''Courage is being scared to death
      - But saddling up anyway''.......John Wayne...
      Anthony
      beaverton oregon
      ^ that is probably a little more the direction i will go. a little more obvious though.
      Scott R. (vinny)
