Results 1 to 11 of 11
Thread: Boxing a frame, questions?
01-20-2011 #1
So I am thinking strongly of trying to box the frame on my syclone
I feel like I am capable of doing it but want to get some ideas from people that have done it. The rear of the frames on these trucks are not boxed but from the back of the cab forward they are. I feel this will help the structure of the truck greatly, one thing I have noticed is when I lift the truck on the rack that the distance between the top of the bed and the back of the cab grows which means the frame is very weak right there.
My plan is to take the bed off and get a bunch of 4x4 blocks that I can stack up under the tires so I can get it 1-2 feet off the ground that way the frame is not twisted or anything. I would remove the brake lines and anything else that would be in the way. I can get some metal and make them fit and weld them in then. Things I wonder are, what thickness metal should I get, should I put the plate flat with the frame and weld it or slightly inside the frame to weld it? Should I leave a little gap so I can get more weld in it then also?
The last part I would like to ask is how good of a welder do you need to be to do something like this? I feel like I am a decent welder but I wouldn't say I'm the best
I am basically self taught so I don't really know the exact "correct" way to weld. I would most likely be using my dads new autoset miller welder (can't remember model #) I would be using it with 110v as the place the truck is currently at doesn't have 220 hookups.
Thanks in advance for all the help you guys can give me I just hope someday I can do some awesome work like a lot of you guys on here are capable of
David Van Hulst
'91 GMC Syclone #892
'92 GMC Sonoma GT #516 Daily
'92 GMC Typhoon #0076 Dads
http://community.webshots.com/user/syclone892
