Thread: Fireplace Inserts!!!
01-17-2011 #1
- Aug 2004
- Connecticut
- 847
I am looking for some info on wood burning fireplace inserts. I have heard very mixed reviews on these. I am looking to heat my family room wich is 25x25. I want to go with an insert in my existing fireplace opening. I have heard that even with the blower system you loose ALOT of heat up the chimney. what are your thoughts. thanks
Paul Krol
1968 Camaro
01-17-2011 #2I've had wood burning fireplace inserts, unvented gas logs, and currently have a free standing wood stove.
The unvented gas logs are very efficient, and while I'm sure somebody may chime in with a concern, new stuff is safe with CO sensors, etc. I actually completely capped my chimney in that house, so all heat was going in the house. But, you're still paying for gas though it certainly was a lot more clean and convenient.
The fireplace insert doesn't lose any more heat up the chimney than a free standing stove. The combustion chamber and the seal of the unit which controls the burn also controls how much is being discharged through the chimney. The problem is that you get a lot less radiant heat because all but one side of the unit are not exposed to the home interior. A blower definitely helps, and the one I had burned so hot and the blower put out so much heat that we never used the high blower setting. Good thing, because the blower sure wasn't whisper quiet. The blower also helps to distribute dust and dirt even more through the room and the house :(
Free standing units radiate tons of heat. I have 2700sq feet upstairs in my house, and about 1200sq feet downstairs not including the garages. The house is "L" shaped. The stove is downstairs on one end of the house. The thermostat is upstairs right in the center. So long as I keep the stove hot, the furnace rarely comes on even in 20 degree weather.
My advice is that if you could possible make a free standing unit work, that's optimal, but the inserts are pretty darned effective.
01-18-2011 #3
