    Page 1 of 3 1 2 3 LastLast
    Results 1 to 20 of 51
      Dec 2010
      St Louis
      Door panel build thread
      I've seen a few threads on making interior door panels and decided to dive in and make my own.
      Well that and the fact new repros for my 72 442 were expensive and ugly.
      So this is my first shot at this, so comments/corrections are welcome.
      I took apart the old door to find the cardboard backing was disintegrating and the top curved metal support corroded. I'm keeping some of the harware, trim, and armrest to use on the new panel.
      So off to buy a sheet of 1/8" pvc.
      I screwed the old corroded metal top edge to the bench.
      Laid down a 2' x 4' piece of pvc and screwed a wood support just behind where I'll make the bend.
      Add heat and bend to follow the contour of the original piece/
      Use the old door for a pattern for holes and to make a rough cut of the outside edge.
      Screw it to the door, mark the edges, make the final cut.
      I'll add a metal lip and felts to the top edge tomorrow. I'm waiting on my christmas tree fasteners.
      Oh and a note on cutting pvc. It's a little like radioactive waste or stripper glitter. Once you get some on you, it seems to get everywhere in the house. So vacuum it up as you go.
      Dec 2007
      michigan
      Thats a good one. haha..
      I'll be keeping tabs on this thread as I am planning on doing my own panels as well.
      2005 CBR 1000RR..."mostly stock".
      1968 camaro... "in the works".
      McAllen, TX
      suscribed~
      Armando Garcia
      67 RS/SS Camaro
      07 Ford Mustang GT/CS
      02 Harley Davidson F-150
      Dec 2010
      St Louis
      I removed the rubber/felt interior seals from the old panels. They're pretty rough and a new set is over $100, cut specifically for a 442.
      The originals are the V shaped ones. I can get generic, universal flat "cat whisker" style locally for $20.
      Pic of V on the left, flat cat whiskers on right.
      I can be a bit sloppier with the fit and save a few bucks if I can find generic V shaped felts.
      Anyone knows who sells that style by the foot?
      Jul 2007
      Los Angeles, CA
      Quote Originally Posted by texasdvldog View Post
      suscribed~
      x2, should be an interesting thread, contemplating this myself.
      California
      Very nice. I had some local shop redo my interior and they did a pretty horrible job on the door panels (they seriously just put velcro on the door and the back of the panel at the bottom). I've been thinking of making my own, but didn't know how difficult it would really be.
      Matt
      Dec 2010
      St Louis
      No luck finding v shaped felts. I bought a strip of the flat whisker felt and bent some light metal strips (1.25 x 0.75") to rivet on and support the felts.
      The door originally had metal clips, but I'm getting the christmas tree clips and drilling new hole to mount them. They look more secure and will be easier to locate the holes accurately.
      Kind of on hold till the clips come in later this week.
      Long Beach, Ca
      Looking like a killer way to make door panels so far. I have been contemplating making my own door panels, and I will be using your idea! My only suggestion would be to add some rubber pads on the backside where it contacts the door frame, to keep it from rattling.
      Jon Rasmussen
      Ex Team OLJ.
      '72 Nova
      Nov 2009
      AR
      Where did you find the 1/8" thick, 2' x 4' sheet of PVC?
      1972 Pontiac LeMans Luxury
      Dec 2010
      St Louis
      I'm adding sound deadener to the inner door metal. That stuff should prevent rattles.
      For a pvc source, I looked up plastics in the yellow pages. Regal Plastics here in St Louis always has what I need in stock. I've also got plexi and lexan from them before.
      A 4 x 8' sheet 1/8" pvc is about $50.
      Feb 2006
      Idaho Falls, Id
      Cool idea using the pvc, I might have to try that some day
      Traven
      Apr 2010
      Littleton, CO
      Sweet build
      1969 Chevy Nova - complete rebuild
      madisonville,tn
      keep us posted!
      Dan
      1969 rs, bbc, tremec 600, 12 bolt, mini tubs, dse a-arms, springs, iforge wheels...
      Sep 2007
      Ventura, ca
      Great idea with the pvc! I will keep an eye on this build for sure. Keep us posted!
      I am not useless, I can still be used as a bad example!
      -Bob
      Mt.Pleasant Pa.
      Looks good so far keep us posted.
      71 olds cutlass supreme convertible
      07 dodge ram
      96 monte carlo
      11 dodge challenger
      http://www.fquick.com/724TIM
      http://s297.photobucket.com/albums/mm206/724tim/
      Dec 2010
      St Louis
      In an effort not to kicked off the Olds boards, I'm copying some of the original Olds features, but updating them. The original woodgrain had to go. I also hated the excess horizontal lines and buttons. So I copied the woodgrain piece with pvc, beveled the edge, laid carbon fiber sticker over it and stuck on a chrome border. Here's a pic of the new insert on the old panel.
      If you want to know why carbon fiber sticker. I did the rest of the dash in carbon fiber rather than the wood grain stickers.
      Dec 2010
      St Louis
      PVC door on the car, lined up for adding a metal lip at the top edge to attach the interior felts.
      I used a small piece of the flat felt as a spacer to align the bent edge of the metal strip with the window.
      Metal strips riveted on:
      Dec 2010
      St Louis
      I'm keeping the horizontal chrome strip off the old door, the armrest, crank, etc... adding the carbon fiber, a speaker, but getting rid of the horizontal lines, buttons, carpet.
      Pic of the old door and stuff transferred to the new one in place. Making sure everything clears.
      Looks like a snow day tomorrow, so hopefully I'll get some foam and vinyl on the doors.
      Aug 2010
      coming along real nice man
      Nov 2009
      AR
      much better look than the wood grain... Great idea here...
