    Results 1 to 20 of 26
      Dec 2009
      San Diego, CA
      PTFE/Teflon Fuel Hose
      Can anybody recommend a good place to get PTFE/Teflon lined fuel hose. I found this place http://www.anfittingsdirect.com/inde...5160b00bcb8d44, but don't know if it is too good to be true. Are all teflon lined hosed created equal? I tried to get local quotes, but were in the area of $250-$300 for 3 lines not totally more than 3 feet combined.
      Apr 2008
      Anaheim, Ca
      I don't know if all ptfe hose is the same, but I got 1 ft with fittings crimped on of high pressure ptfe lined stainless hose that I think was equivalent of 8 or 10 an for $37 at
      http://alternativehose.com/Quote.html
      I forgot to mention hose was intended for a high pressure water line and the fittings were stainless, looked similar to an but not the same.
      Kenneth N.
      1969 Mercury Cougar XR-7 Boss 429 clone under construction
      So. Cal.
      What I replied to on the lateral site.
      Those lines are just fine. I have used many ptfe lined hoses and never had a problem. I use them for gases and fluids of all types. All mine were made in the states so Im not sure if some import (read chinese) lines might have some issues, either with the plastic itself (bad chemistry) or physical issues (maybe too thin in spots).
      There are some great newer lines out that are convoluted and can be bent in some pretty sharp turns VS the smooth bore lines.
      I assemble my own lines and ends with re-usable swivel ends.
      With ptfe core you will be using steel ends VS aluminum ends for rubber core. The aluminum ends are usually defined as AN type fittings. Type meaning they have similar dimensions to AN fittings but not all of them are AN certified.
      But we are flying cars here not aircraft so we dont really need AN certs.
      The steel ends for ptfe core lines are commonly available as JIC (joint industry council) fittings. Its another spec, just as AN (Army and Navy) has a spec.
      You wont go wrong with a decent JIC end, as long as you keep with the standard and assemble the end correctly. No reason you couldnt make up your own hoses with reusable JIC fittings.
      Oh, and when going from hard JIC to AN fittings there isnt an issue because they use the same flare angle. JR
      What I write is opinion, none of it is factual. 2010
      Even though I'm conscious it doesn't mean I'm coherent. 2011
      I'm getting better with age. Best thing about old age is I don't know any better. 2012
      Westminster, MD
      Those are pretty good prices...
      Ed Cooney
      '96 Buick Roadmaster Estate Wagon, LT1/4L60, full bolt-ons & Solomon's tune, 18" Ridler wheels, lowered with Belltech springs
      ‘70 Buick Skylark Convertible project w/ GN drivetrain
      '91 Formula, pending track day build
      Jun 2005
      Lynnwood Wa.
      Check with a local Hydraulic repair shop. They fabricate hydraulic hoses for trucks and construction equipment.
      Oliver Shultz
      It's OK to giggle and snicker. don't laugh and point
      Dec 2009
      San Diego, CA
      Thanks everyone. I went ahead and ordered from the website. Hopefully they arrive Monday so I can finish plumbing the truck
      NJ
      Does anyone know where you can find the Black PTFE hose? All the sites show steel braided hose.
      Dec 2009
      San Diego, CA
      I bought my hose in black from the site I mentioned above. This site has kevlar ptfe hose. http://www.pegasusautoracing.com/gro...pID=PLUMANFLEX
      Aug 2009
      aeroquip.cc is a huge bulk on-line store for ptfe hose. You can get the racing or the industrial hose. The S-TW hose specs out the same as the racing hose for about 1/3 of the price.
      Apr 2010
      Pittsburgh, PA
      frozenboost has flexable SS/teflon lines
      72 buick skylark
      Jun 2010
      Deployed
      Anyone else use AN Fitting Direct.com hose??
      1970 Camaro/DSE build
      Jun 2010
      Arroyo Grande, Ca
      summit racing i just went fuel injection and used PTFE hose with there fittings easy to install i did use petroleum jelly when assembling
      Mar 2014
      Salida Ca
      JDA Enterprises in California stocks a large selection of PTFE hose and fittings in black. They manufacture and supply many major companies fittings and hose.I know their website does not show it. Their phone number is 530-365-8400
      marina ca
      I ordered from an fitting direct and it was bad.
      None of there fittings fit the hoses
      I sent both back and they sent me a new set of an 06 fitting and hoses
      The didn't fit each other either.
      Ended up getting Parker hose and fitting and they fit perfectly
      Mar 2014
      Salida Ca
      Good, but if it's rubber plan on changing it every 4 years
      Jan 2013
      Abbotsford, B.C.
      I know this is an old thread but I ordered my lines and fittings from an direct and had no problems assembling them. I watched Summit's youtube video on how they go together and did it. I used wd40 on the hose to lubricate the fitting so I could pull it up to the sleeve. I also trimmed back the outer rubber layer as it was too thick
      Apr 2010
      Pittsburgh, PA
      This is what i plan to use
      http://www.techafx.com/catalog/49
      72 buick skylark
      Aug 2011
      North Platte,NE
      frozenboost is another supplier that is fair priced.
      Nov 2009
      Austin Texas
      I just ordered a hoses and ends from Orme Brothers. Good service.
      One thing to remember: make sure the PTFE liner is black, not white. Black PTFE means that it has carbon in it so that static voltage doesn't build up and discharge. Sparks and gasoline are a dangerous mix.
      Both Goodridge and XRP make high quality stuff with attractive outer covers and hose ends.
      ​John Parsons
