    Results 1 to 8 of 8
      Feb 2007
      USA, TN
      Ricks Fuel Tank Question
      I have a high pressure and return tube coming out of my Ricks tank in my 71 Nova. Is the left side the high pressure side or is it the right side? I need to reconnect my lines
      Newbury Park, CA
      On mine the pressure side had a steel nut and the return a blue aluminum nut. A quick way to check if the pump is a Walbro (and most others) is to blow into the tube. If it free-flows, that's the return. The pressure outlet on most pumps have a check-valve that will not allow back-flow and will keep the system pressurized.
      Sep 2002
      So. Cal
      Carl, I thought you were going to say something like--"put power to the pump, the one that has gas spitting out is the one" LOL
      Ron DeRaad
      68 Camaro RSx
      Darton Sleeved LS9 - 434ci (4.155x4.00)
      AFR LSX245 Heads (12:1cr)
      660hp/588tq
      Newbury Park, CA
      That would work too Ron, it's just a bit more messy.
      Pensacola, FL
      The tank in my camaro has the pressure line on the drivers side & return on the passenger side. Well they are right next to each other, but that is how i reminded myself which was which.
      Scott
      Newbury Park, CA
      I just pulled mine out of storage. It's the same as Scott's. Pressure on drivers side.
      Sep 2002
      So. Cal
      I can loan a gas can and two hoses... ;)
      Ron DeRaad
      68 Camaro RSx
      660hp/588tq
      Feb 2007
      USA, TN
      Thanks guys. It's taken a while to get the new fuel line ordered. I had to reroute them. Mine has two blue aluminum nuts so I'm going to write an R on the tank so I have a reminder next time.
      Putting power to the pump was always an option. LOL
