Results 1 to 12 of 12
Thread: Brakes
- Nov 2008
- 81
Brakes
Car is 69 Camaro with Wilwood 1 1/8 MC, small vac booster, 6 piston front, and four piston rear. Today was the first time the car was driven on the street with the new brakes.
Brakes feel like they have no power assist. With the car off the pedal is solid after an inch of travel and really doesn't move much more than that with out extreme effort. Car running its a little easier that first inch but after that it is the same. I don't think it is a problem with air in the lines (I vacuum and presure bled the brakes several times).
I measured 15.5"vac at the check valve. The booster is holding vacuum once the car is shut off (I pulled the check valve and hear air rushing in, I also swapped check valves for one off my truck).
I believe it is adjusted right. 1/8in of free play, pedal will go all the way to the floor during bleeding.
I think the booster is bad.... anybody else have any thoughts? Could I pick a new one up at napa? I was suposed to take the car tomorrow and get it tuned, but I dunno if they will drive it with the brakes like this. It stops, but you have to stand on the pedal.
Pete
