      Connecticut
      Muncie 4 speed help
      i need some help figuring out a muncie 4 speed. It was supposed to have come out of a 68 camaro these were the numbers i could find on it 3925660 that was stamped on the side opposite the shifter linkage. On the same side of the shifter linkage i found 3831707 wich is confusing me because they seem like very differnt years. that is all i could find quickly going over it. PLEASE HLEP.
      thank you
      Paul Krol
      1968 Camaro
      Feb 2007
      USA, TN
      Someone changed the side cover is why you see the discrepency. This is common as the holes that hold the shift forks ware out. The important thing is you have a 68+ main case with the 1 inch counter pin. If you order parts for your transmission, make sure to verify if the side cover has bolt on shift arms or studs for nuts. I believe the shift fork styles are interchangeable to the side cover. If the parts have been swapped, you'll want to verify which syncro assemblies are installed as well. The early and late styles will interchange on the main shaft, but the components of each style (slider, blocker rings, etc) are unique to each.
      Connecticut
      Quote Originally Posted by TnBlkC230WZ View Post
      Thank you very much that is what i fugured happend becasue the info leads me to a 68+ case and early side cover. I ran out of day light to see any other number. Thank you for the info
      Paul Krol
      1968 Camaro
      Feb 2007
      USA, TN
      Do you know if it has a 32 or 27 spline output? It is possible someone put a different tail housing on it and upgraded the main shaft to a 1971+.
