      Aug 2009
      yucaipa, ca.
      cage rules and specs... 411
      So questions and concerns have been raised in multiple posts in the past regarding roll cages. I've looked and havnt found the right section in any rule books for the specs rules and dimensions needed for a proper roll cage. Im looking for obviously safety but really something that will fit any class or category. Material doesn't matter nor do bends I just need a link to the proper rules. I've heard chrome moly is to rigid? DOM is what is used for road racing? Just want to do what's correct.
      Does anyone have a link?
      Marc Albright
      66 Nova Chevy II
      DSE chassis
      Engine Builder undecided... Any offers?
      Just starting build April 2010
      Follow my build at:
      https://www.pro-touring.com/showthre...quot-1966-Nova
      san diego
      Read NASA rules and SCCA rules as well as NHRA rules. These should cover most. SIlver state and other openroad races have specific rules as well. Also the mile races have specific rules. Once you read through all of those it ends up being hard to build a cage or roll bar to meet everything, depending on your speeds.
      I would suggest a 1 3/4" DOM with .120 wall thickness.
      main hoop only 4 bends
      back braces not bent
      harness and seat bar
      diagonal across the main hoop
      door bars are tricky, everyone has different specs.
      If you are going with a cage the a-pillar bars can have 1 bend.
      I think the halo bar can only have two bends.
      Gussets at all connections are nice!
      All pieces the same material.
      All mounting points need to have a 6"x6" plate. If its bolted use 3/8" grade 8 fasteners and a backup plate.
      http://cms.scca.com/documents/Club%2...CR-January.pdf
      Start looking about page 83.
      http://www.nasaproracing.com/rules/ccr.pdf
      Action starts on p.59 or so
      http://www.sscc.us/docs/2010%20RULES...%201-19-10.pdf
      Fun starts on page 15
      Plan on mild steel DOM. Some sanctions give n concession any more for 4140 so there's no incentive to spend the extra coin
      Greg Fast
      1970 Camaro RS Clone
      1984 el Camino
      Aug 2009
      yucaipa, ca.
      Thanks TO. Thats what I needed, links are a great place to start. New to the world of road racing so wasnt quite sure of the sanctioning bodies who oversee these types of things. Thanks
      Marc Albright
      66 Nova Chevy II
      DSE chassis
      Follow my build at:
