    Results 1 to 15 of 15
      Aug 2009
      Langley BC, Canada
      Hard Lined rad hoses
      What is the best way to make hard lined rad hoses?
      Materials to attach to the rad and engine?
      Actual metal to use?
      Also what is that heat shrink type stuff guys use instead of hose clamps?
      Kevin Freund
      1961 Impala Drop Top
      Jul 2007
      Los Angeles, CA
      I dunno if I would do hard-line between the motor and radiator. You always want to use something flexible routing to the engine block.
      Aug 2008
      Houston, TX
      I agree...I do not think the radiator inlet/outlets would be too happy when the motor torqued.
      Who is wise? One who learns from every man... Who is strong? One who overpowers his inclinations... Who is rich? One who is satisfied with his lot... Who is honorable? One who honors his fellows" - Ben Zoma, Ethics of the Fathers, 4:1
      Aug 2009
      Langley BC, Canada
      even if I have solid motor mounts and use a rubber coupling like I have seen in pics? Not doubting just learning.....
      Kevin Freund
      Aug 2008
      Houston, TX
      Even with solid motor mounts the frame will twist and torque through a hard corner, not sure how much this ties in but I would never use a completely solid connection... Although If you have a rubber coupling I don't think it will be a problem.
      Aug 2009
      Langley BC, Canada
      Hmmmm if no other info comes along maybe I will just use Earls pro-lite 350 hose to match my othe fuel lines.
      Kevin Freund
      Beach Park IL
      Rubber coupling at both ends and you will be fine just leave an 1 1/2" or so between the hard pipe and the radiator. Steel, Stainless, and Aluminum all work fine but mild steel will corrode from the inside. Aluminum is easiest to put a bead in but if you know someone that has a good beading tool any material would be fine. you do need a bead especially if you are using the heat shrink clamps which are made by Gates and should be available from any good parts store. If not McMaster.com has them.
      Hope this helps
      Donny
      Aug 2009
      Langley BC, Canada
      How do I go about putting a bead in? Will exhaust pipe work for the hard line?
      Kevin Freund
      You can just run a weld bead around the tube. Or buy/borrow/rent a tube beading tool. I've done both, and I've made metal radiator hoses from aluminum, stainless, 4130, and mild steel. All work fine, though aluminum is the best choice. Burns Stainless sells mandrel bent aluminum tube.
      jp
      ​John Parsons
      Beach Park IL
      Tools like this work http://www.aircraftspruce.com/catalo...parkerbead.php
      http://www.tubebeadingtool.com/
      But they are not cheap, the race car shop across the street has an old set of Parker stuff, he won't let me borrow it but he will roll the beads for me.
      May 2010
      Long Island, NY
      post edited.
      Last edited by forcefed68; 01-26-2011 at 04:24 PM. Reason: posted twice by accident
      May 2010
      Long Island, NY
      I used 3 ply 6" long silicone couplers on my water pump, radiator, and t-stat housing. In between those i used stainless pipes which i had bead rolled once i figured out the size and bends i needed. I also dont like the look of worm clamps so i used stainless t-bolt clamps.
      Northern Colorado
      I know this thread is a bit dated, but thought I'd offer my input anyway.
      My cheap and dirty way to get a lip. Cut an 1/8"-3/16" piece of your tubing that you are using. Split it, then slide it over the end of your tubing and edge weld it with the tig. You will have to fill in the spot where you split it, but IMHO it is an easy way to get an even lip. This works well with steel and SS. It may not work as well with Al unless you can really dial your welder down.
      Adam Moyer
      '69 Cutlass "S"
      Rockford Illinois
      I modified a pair of vise grips with a groove on one side and a ball bearing welded in on the other and was able to easily put the bead in with it by going around it several times as I tightened up the vise grips. I was even able to put the bead on the end of one end that was an angle cut and have it follow the edge just right.
      You could probably get away with glueing the ball bearing to the vise grips as long as you put a dimple for it to rest in and go easier on the clamping pressure. If the glue doesn't work at all you have to do is tack the ball in and you are ready to go.
      As most will tell you, aluminum is the best choice. I used short pieces of radiator hose and the Gates plastic shrink clamps. The best place to get them is at mcmaster-carr, the price is less even with shipping than most other places.
      Jun 2010
      Georgia
      aluminum is also a good choice as it weighs much less. The more weight you put on the hoses, the more likely you are to have a failure or leak sooner
