      Aug 2008
      Houston, TX
      Electric Life Windows Stop ~Halfway
      Hello guys,
      I've just finished installing Electric Life Power Windows for my '70 Camaro. I've also just installed new door and roof-rail weatherstripping and window felts (original GM).
      The Power Windows are taking power basically right off the alternator/battery via a 10 gauge cable running from the front, with an ignition activated relay. I have run a 14 gauge dedicated ground wire from the driver's side motor ground (which was intended to ground to the door) back to a main ground near the battery (so the ground is copper all the way back to the battery). Furthermore I have cleaned and lubricated all of the tracks.
      When I roll the windows up they get stuck about 2" from the top. I have tried adjusting them in every direction to no avail, sometimes it gets better but they never hit home. They roll up just fine with the doors open.
      Could this be because the weather strip is new and needs to be broken in??
      Any help will be greatly appreciated.
      Cheers,
      Matt
      Who is wise? One who learns from every man... Who is strong? One who overpowers his inclinations... Who is rich? One who is satisfied with his lot... Who is honorable? One who honors his fellows" - Ben Zoma, Ethics of the Fathers, 4:1
