    Results 1 to 13 of 13
      Aug 2008
      Houston, TX
      Rear Gear too High...Suggestions for New Ratio
      Hello Guys,
      I am using a Currie 9" Unit with 3.50:1 Gears, Tru-Trac, and 31-spline Axles. This was originally set up for an automatic transmission (.70 OD) 68 Camaro. Since that car is now gone (RIP) I have modified and installed this axle into my 1970 Camaro.
      The problem I am having is that when getting into first gear, I have to slip the clutch a little too much for my liking. The motor is tuned properly, the timing is set, no issues there. Also, when in 5th on the highway, I have to be moving AT LEAST 68mph (already post-legal speeds ) to keep the RPM's up and the motor happy. The RPM's are right around 2100-2200 at 75mph...too low.
      I am really considering swapping out the 3.50:1 gears to either 3.89:1 gears (roughly 200-220 RPM increase @2000) or 4.11:1 gears (roughly 350 RPM increase @2000). I just wanted to hear what y'all would recommend and any other suggestions you may have.
      Some quick specs on the car:
      '70 Camaro ~3100-3200lbs
      GMPP zz383 Long-Block
      222/230 @.050 | .509 intake / .528 exhaust lift cam
      Fastburn 62cc Heads
      Edelbrock RPM Air Gap
      Quickfuel 680cfm SS Vacuum Secondary
      Tri-Y 1-5/8 Headers into 2.5" x-pipe
      TKO600
      2.87:1 first gear
      0.64:1 OD
      Any help will be much appreciated
      Cheers,
      Matt
      Who is wise? One who learns from every man... Who is strong? One who overpowers his inclinations... Who is rich? One who is satisfied with his lot... Who is honorable? One who honors his fellows" - Ben Zoma, Ethics of the Fathers, 4:1
