      Hackettstown, NJ
      Component terminology name help
      Looking for the technical name for the part I need.
      I need to raise a processor module in an ECU for clearance reasons.
      What would you call this adapter? Processor or chip spacer? does such a thing exist?
      Been looking at the Mouser book but haven't found a picture or description of what it is I need.
      Hackettstown, NJ
      I envision the part to have female recepticals for the prom chip pins and pins on the other side to plug into the ECU board receptical.
      Basically this would have the same principle as a carb spacer.
      san diego
      DIP chip socket? you can stack dip sockets to raise your chip. I did a quick search an found these http://www.arieselec.com/products/dip.htm.
      Hackettstown, NJ
      standoff google image search landed a pic of this guy..
      https://docs.google.com/viewer?url=h...s/pdf/023N.pdf
      not sure if standoff is the name, but we found the part. thanks
      yes..DIP, IC is the thing.
