    Results 1 to 12 of 12
      May 2010
      Virginia Beach, VA
      Speedtech lower control arms
      I'm currently attempting to install speedtech LCAs, the problem I'm having is the bushings won't clear my subframe mounts by and 1/8-1/4 inch on the inside.
      Is the powder coating that thick? Should I sand the powdercoating off? I don't want to modify the arms for obvious reasons.
      Thanks for any help
      England
      have you original lca's can you take a measurement and compare ,I know the original lca can be a pain to fit.Don't forget to slap a load of silcone gel around the bushes .
      Oct 2007
      common problem... get a piece of threaded rod some washers and nuts... put the nuts and washers on the interior side then then them forcing the frame to open up a bit
      67 Camaro In progress
      Calgary, Alberta
      Quote Originally Posted by XLexusTech View Post
      That's exactly what I had to do to get my Speedtech arms in on my '69 Firebird. Only took a couple of minutes per side to do.
      May 2002
      Northern California
      Some go in tight. I have and to use a floor jack to help slide them in. The delrin or poly type bushings don't give like the factory rubber.
      Set floor jack under frame, lay the spring pocket into jack plate. Jack up while guiding into bushing slots. You may have to wiggle the arm a bit. Should slide right in. Don't be shy with the lube.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      May 2010
      Virginia Beach, VA
      Thanks for the help ill try it again in the morning ill write my results up
      Mountain View, CA
      True T.
      My blog
      St George Utah
      the instructions actually show the process described above. this is the MOST common problem. the factory sub frames get collapsed during bushing changes over the years. it is not an issue with the control arms.
      Blake Foster
      www.speedtechperformance.com
      435-628-4300
      St. George Utah.
      it's always sunny here.
      May 2010
      Virginia Beach, VA
      Thanks for the help I got them in, it took a few persuasive words but they are in
      St George Utah
      there you go
      Blake Foster
      435-628-4300
      St. George Utah.
      Macon, Ga.
      Dang it Blake, I was going to suggest a BFH, those fix anything, of course I am a carpenter by trade.....haha
      Bill
      Trailers are for BOATS!
      St George Utah
      yea that would have worked also, thanks for the help Bill, we will ad that you our instructions.
      Blake Foster
      435-628-4300
      St. George Utah.
