      Feb 2007
      charcoal canister?
      what is the best charcoal canister to use? its going in a 79 camaro with a ls1 the evap has been deleted from the pcm so i will just need to run the line from the tank to the canister and then to the purge valve port on the engine. I do not want to run a vented cap.
      If you have any info make model or better yet a part number that would be great
      Brandon Slater
      1979 Z28
      1972 Nova
      2015 2500 silverado crew cab duramax
