12-10-2010 #1
Difference between Tremec 5 and 6 speed?
Im building a 66 Nova and it will have an LS motor with an estimated 700 - 800 horsepower. Im obviously planning on putting a Tremec in but dont know the proper trans to put in. I am trying to decide between the 6 speed and 5 speed but besides the 1 gear are there any advantages to going with the 6 speed. I know you can cruise the freeways better and get better gas milage but as for the 5 speed how bad is it to cruise the 5 speed. I will have 3.89 gears if that helps with any advice. I just dont know if that one extra gear solely for cruising the freeway is worth it.
Also if anyone could provide model and part numbers of transmissions that would be helpful too. Brand new to some of these things and just curious where to go from here.
Marc Albright
66 Nova Chevy II
DSE chassis
Engine Builder undecided... Any offers?
Just starting build April 2010
Follow my build at:
https://www.pro-touring.com/showthre...quot-1966-Nova
12-10-2010 #2
- Apr 2008
- Anaheim, Ca
- 99
You probably should include which 5 & 6 speeds you are looking at because tremec makes them in several flavors. t45, tko, t56, t56 magnum, t5, 3650 etc
and then to complicate things keisler has a rs600 or whatever that's a beefed up t45 which itself I *think* is just a 5 speed version of the t56.
I myself am thinking long and hard about a t56 magnum vs a rs600. I'm leaning towards the 600 cause I can give up a gear for less cutting in a cougar, and it should be cheaper.Kenneth N.
1969 Mercury Cougar XR-7 Boss 429 clone under construction
12-11-2010 #3
Banned
- Aug 2003
- Orlando, FL
- 8,745
T56 Magnum IS the choice for you. Since coming out we are selling T56 Magnum kits over TKO 600 kits 4 to 1. The T56 shifts smoother and will handle 100 more lb ft of tq then the TKO 600. 700 tq and 600 tq.
12-11-2010 #4
- Feb 2007
- USA, TN
- 850
Both the T56-magnum and the TKO600 have a similar top gear which will work well with your 3.89 gear. The big advantage of the T56 magnum is it has an extra gear at .80 ratio that really helps in-town cruising. I use it at 35 - 40 mph. The magnum is heavily based on an OEM transmission which has OEM durability, reliability, shift quality and mfg tolerance requirements built in.
01-02-2011 #5Thanks guys. Im going to do some research on it but the magnum is a 5 speed or 6 speed? Your saying that "extra" gear so Im not sure if thats a 5 or a 6 speed. How does the T56 Magnum do for freeway or open road cruising?
Marc Albright
66 Nova Chevy II
DSE chassis
Follow my build at:
01-03-2011 #6
- Apr 2008
- Anaheim, Ca
- 99
The Magnum is a 6 speed. Both 5th and 6th gear are OD gears with 5th essentially being the "extra" gear with .80 in terms of ratios. Example
a 5 speed will have
for example
4th 1:1
5th 0.62:1
and the magnum
4th 1:1
5th 0.8:1
6th 0.62:1
I made up the approximate ratios since I'm not going to look it up but with the 6speed you have the extra OD thats not as steep.Kenneth N.
01-05-2011 #7Thanks that's a huge help. DSE did the install of my trans crossmember and it is adjustable to a certain point. Is there anywhere to get the measurement length of a TKO600 and a T56 magnum bell housing to trans mount? This will be the deciding factor on what I can run. I originally chose the TKO but am kinda having second thoughts based of that extra gear for cruising not to mention the strength factor.
Any estimated prices on either of these transmissions?
Marc Albright
66 Nova Chevy II
DSE chassis
Follow my build at:
01-11-2011 #8
Starting The Transformation
- Dec 2008
- Knoxville, TN
- 363
Hi Marc,
Check out the discussion here.
- Shafi
