      Apr 2010
      Pittsburgh, PA
      spring free floating height
      I just have a quick queation on free floating height.
      Will one inch taller free floating height over stock make the springs actually sit one inches taller, or what's the deal?
      I originally bought rear springs that had the same specs as stock replacement except the free floating height is about an inch longer. I did this to make sure the massize 325-50s would fit with gas shocks rather then the use of stupid air shocks
      I'm just asking AS i know plan to run a 295-50-15 on street and some 315-35-17s for track days and dont want it to look stupid from a big gap between top of tire to quarter lip!
      Thanks in advance
      Mike
      72 buick skylark
      san diego
      They will sit 1" higher.
      Mar 2010
      AZ
      Quote Originally Posted by Bryce View Post
      So long as the springrate is exactly the same.
      Robert R.
      1988 S10 blazer 5.0L SBC 700R4 body off build.
      1991 S10 Blazer 4.3L too low daily.
      1975 Cutlass Salon currenlty 350/th350
      Stupidity should be painful.
      san diego
      True, he did say they were the same spec springs.
      SoCal
      Does same spec imply the coil is the same but longer or that the spring rate is the same? Just lengthening a spring with equivalent diameter coil will result in a different spring rate.
      Brett H.
      1979 Pontiac Firebird Trans Am
      1991 Mazda Miata
      2005 Ford Mustang GT
      1987 Ford Mustang GT - Sold 06-29-2014
      1988 Oldsmobile Cutlass Ciera - RIP 9-17-2011
      1992 Chevrolet Corvette - Sold 10-12-2017
      Apr 2010
      Pittsburgh, PA
      i dont remember about the coil thickness but the spring rate was the same, the free floating height was an inch longer
      72 buick skylark
      Mar 2010
      AZ
      Then it will be one inch higher.
      Robert R.
