Thread: Del-A-Lum Bushing Tightness
11-20-2010 #1
How tight should the upper control arm shaft be after installing Del-A-Lum bushings? Mine seems too tight. I can move the cross-shaft by putting a large screwdriver through a mounting hole, but it requires some effort. I'm wondering if I have the nuts too tight. I torqued to 15 ft-lbs per the instructions (10-15 ft-lbs).
I'm installing #1014 bushings with the #705 Offset Crossshaft.
Ken C.
