Thread: Alignment Specs
11-19-2010 #1
Alignment Specs
I'm looking for opinions on what specs I should set my caster/camber/toe to when I get the front end all put back together. My 69 Firebird is 90% street/10% track car. Real heavy in full street trim. Probably 3700lbs. I put on about 5K miles a year. I don't want to run the track settings on the street and wear the inside of the tires out. I run Firehawk 235/60/14 street and 27.5/9/15 Eagle Sports Car Specials at the track.
The new UCAs are said to have 5* caster built in to them. Sounds like 6* is about the limit of what is needed.
I heard people running 0*to neg 2.5* camber. It seems to me I read back in the day that 3/4-1* neg is what I should shoot for.
I suppose factory toe specs are fine for all around use.
Maybe I should get one of those adjustment gauges so I could run 1/2* neg camber/6* caster and slight toe out on the street and shim it up to neg 2* on track days. I wouldn't think adding the same shims front and back would change the caster setting, only the camber, right?
Any suggestions on settings for either or both would be appreciated.
Robert
Any
