    Page 2 of 2 FirstFirst 1 2
    Results 21 to 24 of 24
    1. #21
      Beach Park IL
      I don't think the preload exploded your shocks....
    2. #22
      Mountain Springs, Texas
      Maybe a bad choice of words on my part. But the high preload extended the shock to it's max with high force when I hit the drop in the road. There was a loud bang. I used the instructions supplied in the pdf and changed my spring rate. No issues since then. The explanation and calculation in the pdf make good sense to me but I am not a mechanical engineer or suspension guru by any means.
      Anyway, hopefully there is some value here.
      1957 Buick Estate Wagon
      1959 Apache Fleetside
    3. #23
      Mar 2010
      AZ
      That is exactly why I suggested a limiting strap, with a spring longer than suggested you could pull the rod too far up in the shock and slam the valve body into the top of the housing. It's not common by any means, but it can happen. Spring rate alone should not cause it though, it would have to be too long of a spring, or a spring installed with the housing cranked too high. This is often called pre-load, but the only way it could technically be pre-load is if you have the coil mounted directly to the shock at upper and lower, and the shock is maxed out, then a load is put onto the spring prior to the weight of the vehicle being on it. This could be VERY hard on a coil-over and I would generally advise against it. Dialing the ride height up once weight is on it is fine by all means, but it is not the same. Anytime you are putting a significant load on the shock at it's max height, it could and eventually will cause a failure, unless the shock has been specifically designed with an internal bump stop to prevent damage.
      Robert R.
      1988 S10 blazer 5.0L SBC 700R4 body off build.
      1991 S10 Blazer 4.3L too low daily.
      1975 Cutlass Salon currenlty 350/th350
      Stupidity should be painful.
    4. #24
      Oct 2010
      Cincinnati
      Decent shocks (like afco) have a bump rubber on the shaft inside the shock body for this exact reason. I wouldn't worry about failure, but It will make some noise and upset the car when it hits full extension.
