      Oct 2006
      McKinney, TX
      fuel line limits
      I've been doing some research and it seems that everyone runs either 3/8" or 1/2" line. What I can't seem to track down is the reason for running one or the other. Obviously the 1/2 runs more fuel, but what are the limitations of 3/8?
      If I run 1/2 and it is "overkill" will will it have a negative effect?
      Confucius says, "Choose a job you love, and you will never have to work a day in your life"
      My build Beast
      Aug 2008
      Pgh, PA
      No problems with overkill. The only thing 1/2" costs you is that it's a little more difficult to route hard lines in some places because of the extra OD, in stainless particularly it's tougher to bend, and it's a little more expensive. I honestly don't know the limitations of 3/8 myself, but was cautioned to run 1/2" in my build.
      Oct 2006
      McKinney, TX
      Quote Originally Posted by wmhjr View Post
      Sounds like I'll be running 3/8. Thanks for the info.
      My build Beast
      Dunwoody, GA
      3/8" is basically what the factory runs with LSx engines. I've built a few 500+ hp LSx engines and have no fuel supply issues using stock fuel lines and just an upgraded pump. Bill is correct though about the differences between them.
      Trey
      ~ Jon Hammond
      san diego
      Flow is dependent on area and pressure.
      Jul 2007
      Los Angeles, CA
      Double 1/2" lines will still fit, just takes some time mocking up and thinking about it. Even 5/8" will fit least will before the axle:
      Stainless is harder to bend, but just requires a good bender (Rigid).
      Mar 2010
      Alabama
      Yes 5/8" will still fit because I am running dual 5/8" lines on my 67 camaro blow-thru application.I would recommend on going with 1/2" and the reason I say this is for future need. If you ever need to go up with fuel volume then you will have the correct line size without changing. That is just my opinion.
