    Page 5 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
    Results 81 to 100 of 133
    1. #81
      san diego
      Nice! I think I know, HEEHHEHE. See you at RTTC.
    2. #82
      Mar 2010
      Tempe, AZ
      Making progress...
      The start of some brackets:
      Certain pieces are starting to come together:
      Picking up a whole bunch of goodies tomorrow :D
      1967 Camaro - LM7, T56, TVS, 12.7:1
      1996 Impala SS - DD
    3. #83
      san diego
      Sep 2009
      I love the stock looking appearance. Nice car.
    5. #85
      Mar 2010
      Tempe, AZ
      ooo what could this be...
      No fancy welding table needed.
      Not the prettiest welds ever...
      ... but I got good penetration.
      And most importantly, I did it myself
      Thank god this is a long weekend. Have a ton to do before RTTC, but I'll make it or die trying.
      1996 Impala SS - DD
    6. #86
      san diego
      Quote Originally Posted by LM7_67 View Post
      Not bad for an engineer!
    7. #87
      Oct 2011
      Lost
      Some Hard Core work and driving...well done..
    8. #88
      May 2011
      Central FL
      I hate to say it since I enjoy watching your build, but those welds look "cold". There may be some welded metal in the center of the pool, but the edges of the weld look like they are sitting on top of the parts from too little heat/current. You might want to try testing the bond by hitting the end piece with a hammer to see if you can knock it off. If it were me, I would grind it all down and go a little slower with the torch.
      What I think you have is the bead picture in "100A" where there isn't enough heat to properly weld the two pieces together. A proper heat affected zone (discoloration around the weld) would also be more noticeable.
      What you are shooting for is more like this where the weld is uniform across the added metal from the wire. The discoloration from the applied heat is also more noticeable on both work pieces.
      Slow down as you weld the pieces and make sure you have a good view of the puddle as you work. Hope this helps.
      - David
      1967 Camaro - In remembrance of my friend Scott
    9. #89
      Mar 2010
      Tempe, AZ
      Quote Originally Posted by MyFriendScott View Post
      Thanks for the advice. I tried the hammer trick, and smacking them with a deadblow didn't seem to phase them. I looked over the welds pretty closely, and there's a mix of the colder "sitting on top" and the hotter "more sunken in" weld.
      1996 Impala SS - DD
    10. #90
      Mar 2010
      Tempe, AZ
      Some other goodies that will be making it on to the car during this upgrade:
      Spent most of Sunday making this front crossmember:
      Springs pockets modified to accept LCAs:
      Mocking up the watts frame. The mounting points for the coilovers will be built off of this:
      Front crossmember finished!
      All and all, about where I wanted to be at the end of this weekend.
      1996 Impala SS - DD
    11. #91
      Long Beach, Ca
      Check you out! Is there any reason you are using a uni-ball on the front of the control arms and not another heim?
      I'll be looking at this out at RTTC. Good luck on the rest of it.
      Jon Rasmussen
      Ex Team OLJ.
      '72 Nova
    12. #92
      Mar 2010
      Tempe, AZ
      Quote Originally Posted by Nessumsar View Post
      Jon! Yeah, I'm hoping the urethane-bushed uni-balls will cut down on the road noise transferred by heims. See you at RTTC!
      1996 Impala SS - DD
    13. #93
      Nice porogress. That is a nice brake set up. They make a great product.
    14. #94
      Huntington Beach, CA
      I see the addiction is in full swing Tom. Haha I hope you make RTTC!
    15. #95
      Mar 2010
      Tempe, AZ
      Mid-week update. Not much has happened in the past 8 days as I spent the weekend skiing in Utah.
      This is a great sight. Still a bunch more to do, but I can see the end now. Hopefully most everything will be wrapped up after this weekend.
      Spent a lot of time creating this before I cut the first piece of metal. I can't take credit for the housing/carrier though; found those online.
      1996 Impala SS - DD
    16. #96
      Long Beach, Ca
      Muy bueno!
      Jon Rasmussen
      Ex Team OLJ.
      '72 Nova
    17. #97
      Feb 2010
      ARIZONA
      Looking great Tom! Nice CAD work too! Looks like a nice homemade axle tab location jig also. It shows that you don't need all kinds of expensive tools and stuff to build a cool car. Now I just have to get out to the garage and work on mine.
      Larry
      67 Camaro, 350 SB, Custom A-Arms & 3-Link
      My Build https://www.pro-touring.com/showthre...LOVE-67-Camaro
    18. #98
      Mar 2010
      Tempe, AZ
      Quote Originally Posted by MIKE67 View Post
      Thanks Larry! Can't wait to see yours on the road.
      Picked up the last of the real hardware today.
      These should be a good starting point.
      I thought this was heavy. Would not want to pick up an iron one.
      1996 Impala SS - DD
    19. #99
      Jun 2006
      Phoenix
      Tom,, From the looks of the scale on the floor (in the last pic.). You can not take weight out of the car by setting the scale at -5lbs before you weigh anything.. lol Looks good man. Roger
      1995 Caprice 6.0 LQ4,L92,L76 Leading Edge Performance Tuned
      http://www.cardomain.com/ride/456803...caprice/page-1
    20. #100
      Mar 2010
      Tempe, AZ
      Last weekend before RTTC....
      Most of Saturday was spent finalizing the upper coilover crossmember. I wish this ended up being lighter, oh well.
      Mocking up the torque arm
      Coilovers in place
      Torque arm finished up
      Where I left off tonight
      Will be back at again tomorrow night. Luckily all the fab work is done, just have to assemble everything now.
      1996 Impala SS - DD
