      San Diego
      Opinions about Leaf Spring Pads
      I am ready to install a new 12-bolt rear end in my 68 Camaro with DSE 3" drop multi-leaf springs. For the guys running the DSE springs or similar springs, did you use mounting pads or not. What are the pros and cons of not using mounting pads? Thanks
      Jan 2003
      Arizona
      Sorry Brad. I've been driving all day. I'm in a hotel and can receive email but cannot send. Here's my reply:
      Hey Brad,
      I have poly pads installed but they are not necessary. They CAN help a little bit to locate the rear on the pins. If you are anxious to put it all together I wouldn't worry about the pads. Or put it together and then loonse the hardware and slide the pads in later. You can do so without much work (Jackstands under frame, remove nuts from U-Bolts, jack rear up 2", slide in pads--Watch your fingers. You don't even have to undo the driveshaft).
      /Steve
      ________________
      Steve Chryssos
      San Diego
      Thanks for the info Steve. No need to apologize. I still have to get new lower shock mounts so it souds like I might as well get the poly pads at the same time.
      Dec 2002
      Lost Wages, Nevada
      I havent used pads in any of my builds in the past 15 years or so..... I guess I have just stuck to that idea from the get go.
      May 2002
      Northern California
      it mainly for the reduction of NVH. I don't use them anymore either.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      San Diego
      Thanks alot for the opinions guys.
