    Page 2 of 2 FirstFirst 1 2
    Results 21 to 34 of 34
    1. #21
      Oct 2010
      Cincinnati
      Do you have adjustable shocks? Taking out some rear rebound may also help what you are describing.
    2. #22
      Dec 2009
      El Dorado Hills
      Quote Originally Posted by U_SAY_GO View Post
      Yes, I do have single adjustable QA-1's but currently researching other shocks. It makes more sense to try and transfer work to the front of the car. I think I am going to take some weight off the rear also. I currently have a DSE 1 1/8" hollow front sway bar. I'm thinking of trying a 1 1/2" front bar and see what happens.
      Gaetano Cosentino
      Dont Drive Faster Than Your Angels Can Fly
    3. #23
      Auburn, WA
      Quote Originally Posted by Wicked View Post
      With a live axle, the tires surface and axle will always remain parallel to the ground. Not as much to be gained on the rear.
      Well, that's not exactly true. You don't always want the tire parallel to the ground, because tires perform their best with some degree of negative camber (the amount depends on the tire used).
      My experience is this: adding rear camber will give you enough rear grip to require a heavier rear bar. That's a pretty big deal. If you don't think adding rear camber will help rear grip, then you need to try it for yourself.
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
    4. #24
      Nov 2002
      state of confusion
      Up to at least 0.75° total angle (considering camber and toe) in a non-floating axle shouldn't be any problem. That's about where the total has been in the axle that's been under my Malibu for 15 years of use and somewhere around 100,000 miles.
      A little history - this isn't the original axle for the car due to loss of a C-clip while on the road that trashed everything inside, so some of that "misalignment" could have been the result of ITS original car being totalled. The diff has been replaced twice since, first time due to an opportunity to swap limited slip 3.27's in where the replacement axle had 2.56 (open). Second time was due to ring and pinion gear tooth breakage (EFI 355 + Tremec + 26 spline corporate 7.5"/7.625" is kind of iffy), at which time I replaced the driver side axle shaft due to the splines starting to show some twist.
      But there have been no failures directly attributable to that axle housing/tubes having a little over -0.5° camber and there being somewhat less toe. Yes, I'd like to trade some (most) of the excessive toe for a little more negative camber.
      Something else to consider - a solid axle with wheels and tires actually has a "roll stiffness" of its own just due to the fact that tire vertical stiffness is finite. Somewhere around 1°/g worth is probably a good enough number to use in most cases. IOW, if you see an end-on picture of a car cornering up around autocross-hard and you measure it with a protractor to have 4° of roll, 1° of that is apparent roll from tire deflection and the chassis/suspension roll stiffness is a little higher than you might have first thought at 3°/g instead of the whole 4°/g.
      Norm
      Gone but not forgotten dep't:
    5. #25
      Oct 2009
      New Derry, PA
      Quote Originally Posted by silver69camaro View Post
      When that tire is 20" wide, it helps a lot! Name:  lonnie slc.jpg
    6. #26
      May 2002
      Northern California
      Quote Originally Posted by Gitter Dun View Post
      Here are a couple of picks showing lateral loads on rear tires. Not sure if it would be worth building neg. camber into rear axle but that is one idea I am thinking about.
      thats actually normal with the low RC you get with leafs and the sidewall you have. Also didn't help with leaky locked up shocks. Remember with all the mods and at that speed the force has to be applied somewhere right? Its to the tires where it belongs. Playing with air pressures would help with temp readings.
      You would gain more putting the money into a dampning system that actually works. A link or IRS suspension would add adjustibility/tunebility to the mix.
      To add, upgrading to larger brakes will help you go deeper into the turns and will help you carry more speed out of them.
      You get to that bank we always talked about? LOL
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
    7. #27
      Dec 2009
      El Dorado Hills
      I was wondering when your arse was gonna chime in. Got an iron on the fire and hoping it follows through. If so I hope to drop the car off in about a month. Yes, we still have alot of work to do.
      Gaetano Cosentino
    8. #28
      May 2002
      Northern California
      I like to sit back and analyze other responses before I chime in. I hate echoing something that has been added already.
      edit: in your case would be a band aid for your existing suspension deficiencies. ie shocks, tire pressures, tire contact patch, weight balance.
      What we do not see or interpret from your photo is your speed, if your accelerating and if you at the correct apex for that particular turn.
      Lets go with the small stuff and work your way up to the advance stuff.
      We had a few track cars running camber in the rear and then we noticed seal failure. That was back in the 90's and the technology that exists today might make it worth the effort. I believe the Speedway floater that JCG's is setting up might be the hot ticket. Lets see how that performs.
      Being able to adjust camber and toe would be something I am looking at now.
    9. #29
      Jun 2009
      Matt,
      Please respect that yours isn't the only experience or opinion.
      My response was in reference to adding camber to a solid axle and the wear issues(bearing, etc) that could result. I never said camber in the rear is useless. My point was the gain was small compared to the drawbacks for what he's asking. You obviously have done this yourself and tested it fully back to back with a standard live axle?
      I have multiple vehicles running INDEPENDENT rear susp and of course we prescribe rear camber. But the point of the camber is to yield a mostly flat tire patch when the vehicle has taken a set in the corner(i.e.roll, camber gain in compression).
      Bradley Buchanan
      Mechanical Engineer
      Honda
    10. #30
      Auburn, WA
      Bradley,
      My mistake, I misinterpreted your post. There shouldn't be any bearing or wear issues if done properly, and the gains are pretty big. I can see how the gain may seem minimal compared to the work involved to get to that point, as most people don't have the resources I have, and I know sometimes I take that for granted.
      In my experience, the rear roll stiffness needs to be increased by about 8-10% to bring the vehicle back to a neutral state after camber is added (and I believe part of that is attributed to the large tire stagger). I'd be interested to run 0 rear camber in my BMW to see if the change is as dramatic. I should also note that along with the increased camber is toe-in, which does wonders as well.
      If you're a ME from Honda, perhaps you can answer this for me: Do most OE's run high amounts of rear camber to keep the vehicle in a state of understeer? Or is there another reason? Just something I've always wondered about.
      Matt Jones
      Mechanical Engineer
    11. #31
      Jun 2009
      Bradley,
      Trust me, I'd love for my normal job to be in a more high-performance capacity.
      Is your Bimmer IRS? Really just depends on much work the rear is already doing.
      In most of our multilink rear suspensions, we only adjust toe at the factory. The toe is adjusted via a cam bolt on one of the lower links. The toe change also affects the camber. Depending on the vehicle, camber range is between 0 and -1 degrees or so at normal ride height. When loaded the suspension does gain a lot of camber. This is just result of the upper arm being shorter than the lower. This obviously doesn't yield the best camber curve, but is more compact.
      The toe in setting(0.08 degrees per side) helps to maintain an understeering vehicle. On the Odyssey, the lack of a rear sway bar is another "feature" that helps maintain a safer understeer tendency. On our race version(yes, race minivan), we built an adjusteble rear bar setup. The car also makes 532whp at the front wheels....so having the rear do a little more work was a necessity.
    12. #32
      Another thing to be cautious of is the change that can occur from toe in to toe out because of pinion angle change. The more camber you have the better control you need to have of the pinion angle. I have a 1.5 degree negative cambered rear using a full floater and I could not run it with leafs even though I have extra stiffness in the front of the leafs. It got very nervous coming off corners. It is best to use a link type of suspension that does not change pinion angle as much. In regards to effectiveness they do make a difference in grip and will require suspension rate changes as mentioned previously. My first experience with a cambered rear was a transaxle Alfa with a DeDion rear that I changed to cambered. A DeDion behaves similiar to a live rear except for being lighter and having less suspension anti properties. It made the car far more predictable at the limits. It gave me confidence to try the cambered rear on my V8. It made a larger difference with the powerful but heavy pig Mustang I drive. Still will never be a true sports car, but does increase grip noticebly.
      I had stock car products set up my housing, but speedway engineering does them too. SCP has changed names so I'm not sure what they do now. I do not worry about durability of the axles, the drive plates or the hubs - it is beefy stuff and well proven. I went to 5x5 wheels so I could use all of the brake hats, etc available for cup cars. There several different types of hubs for floaters as well with superspeedway being the strongest (and heaviest).
      Many times you can find new surplus stock car parts at less than 1/2 cost if you look around and call folks like Tex racing and some of the cup teams. Another option is to buy a used (but not crashed and bent) floater housing with plus and minus camber and have speedway cut off the plus side and match the camber of the neg side with a new cambered tube. Crowned axles are about $125 each new and new hardened drive plates can be had for about $60 if you look.
      70 Mach I, dry sump & lots of mods
      70 1/2 Z28 project car
    13. #33
      Oct 2009
      New Derry, PA
      Quote Originally Posted by funcars View Post
      If you are determined to try it, and want to go to a floater, companies like Coleman and Winters make pre-cambered "kits"; where you have a straight flange on the housing, and only the bolt-on floater snout is cambered. This offers the advantage of being able to buy ends with different amounts of camber built in, instead of tweaking the actual housing.
    14. #34
      Jun 2006
      Katy,TX
      I want to think Herb Adams showed using as small cut in the tubes(10/12 bolts) and slow rewelding to get some camber back in one of his books or news letters back in the late 70s early 80s.
