    Results 1 to 9 of 9
      Nov 2007
      Oro Valley, AZ
      Anyone else gone with TBI?
      My current plan for the 383 I'm building for my truck involves TBI. I already have a 454 throttle body and already have a cam in mind. I'd like to convert to port injection in the future, but being this is my primary transportation I'm sticking with mostly stock parts that will be plug & play with the current TBI setup. I read about a TPI-fed 383 @ about 10.5:1 with ported L98 heads and it made good power & torque with the cam I have, which is part of the reason I chose it (the powerband is in a good range too).
      -Darren-
      '78, '81 Malibu, '92 Sierra
      Quote Originally Posted by joemac View Post
      ...not only am I talking to myself as I'm going down the road I'm starting to answer myself and laugh at my own jokes-out loud...
      Go to thirdgen.org and read the tbi section. You will be amazed what people have done.
      1992 Z28 vortec 350 auto hardtop
      2001 regency Sierra 4.8 stepside slammed with big wheels
      1992 RS heritage edition 305 5 speed t tops (Sold)
      1991 z28 350 hardtop 12k miles (sold)
      1996 Z28 44k miles (sold)
      1994 z28 vert (sold)
      1979 Z28 (sold)
      1991 S10 350 swap (sold)
      and a ton more...
      Nov 2007
      Oro Valley, AZ
      I'm already on TGO ;) I'm just curious if anyone here has done it. I'm running an EBL setup on the TBI 4.3 that's in the truck, and it's been great so far.
      -Darren-
      Which ebl? Dynamics?
      I have a 305 tbi car as a DD that is modded decently in the susp department. I am adding headers, vortec heads from my other car that is getting afr's. They both are gonna be ran off the dynamics set up.
      1979 Z28 (sold)
      and a ton more...
      Nov 2007
      Oro Valley, AZ
      Yep, DynamicEFI. Down the road I hope to make the change to TPI or other port injection, but like I said before the reason I'm sticking with TBI right now is because it's basically plug & play, and I don't have to make any changes to wiring, etc., and I'll be able to basically bolt the 383 in.
      -Darren-
      Yea I'm using them also on my cars, I have a 1992 z28 tpi car also' I'm gonna leave my one car a tbi car and just do heads, cam, full exhaust and drive it. It's a low mile heritage car so don't want to tear it up to bad. Tell me how you like dynamics, I can't wait to get my together with everything.
      1979 Z28 (sold)
      and a ton more...
      Nov 2007
      Oro Valley, AZ
      I like it a lot. Since the truck is currently a stock 4.3 I was able to flash it with one of the included tunes and it fired right up, and runs better than it did with the stock computer. With my truck's harness there is no air pump, so the plug for whatever valve is used with it was just tied to the harness at the factory... the cool thing is the EBL uses that wire for a trigger lead for an electric fan relay, which I plan on putting in eventually. The nice thing is I know it's there, and basically all I have to do is wire it up, and choose an on/off temperature in the tune. The What's Up Display already shows it sends a signal to turn it on when the A/C is on. I really want to get a wideband O2 sensor so I can tune this thing for WOT, but that's another $200+.
      -Darren-
      I have heard great things about it. This will be my first time doing tuning but I plan to learn. As for you switching to muiltport have you considered a LT1 intake setup? Stealth ram? mini ram? super ram? They would work great on something with more power then stock.
      I can't wait to start messing with dynamics!
      1979 Z28 (sold)
      and a ton more...
      Nov 2007
      Oro Valley, AZ
      I'm pretty sure I won't be able to use an LT1 intake since it's reverse cooling. I am looking into other intakes besides TPI, but if they don't have EGR I won't be able to use them, at least so long as I live in the specific emissions-required areas.
      -Darren-
