    Results 1 to 20 of 26
      Oct 2007
      ATS Tall spindles Brake and Rim Combos Post yours up
      Looking for a good option for my 67 F body camaro. I picked up a set of new int eh box ATS tall spindles from another member here and want to start researching rim and brake combos that will work.
      For brakes i am considering the z06 kit from Kore3 but mot sure if their are limitations on rim sizes with the ATS tall... My can Stock Sub BTW but I may notch it..
      Thanks all
      67 Camaro In progress
      May 2002
      Northern California
      Quote Originally Posted by XLexusTech View Post
      Thanks all
      The only limitation (besides your obvious sheetmetal) would come from your steering arm and rim...L&H kustoms has a short steering arm to help this. Rim minimum would be 17". Nail your back spacing and 275's would be on the menu...have you been drinking? LOL
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Oct 2007
      Cool.. thanks for the tip on the Arms.... OMG I just read my Orig post....Cant spell, cant type... Glad I can weld :-)
      Dec 2007
      Salem, OR
      The "regular" size C5/C6 Kore3 brakes will not clear 17" TTII's. I have 17" Raceline GT wheels and they do clear.
      Mike R
      '66 Olds Cutlass Convertible
      '15 Challenger SRT 392 (DD)
      '72 Pontiac LeMans (wife's toy)
      May 2002
      Northern California
      yep, C5/C6 will have spoke issues. We had used a 5/16" spacer to work.
      Oct 2007
      would they have worked with 18" wheels?
      May 2002
      Northern California
      not sure, but it has to do with the spoke design...you can specify c5/c6 clearance with most rim makers.
      Netherlands
      MRQuik what do you mean minimum rims size is 17 inch??
      May 2002
      Northern California
      Hi David, I don't know anyone that has been able to run ATS and C5 brakes with anything less than a 17" rim. If you know a combo let me know. That has been the deal breaker with some of our customers.
      Vince
      Netherlands
      right now we are working together with brake man brakes and bogard racing wheels on a 16 inch rim combo and 13 inch brake system. with the ATS tall spindel
      for my 68 firebird. c5 mounting braket needed to be custom made with ofset holles. Im getting confused and scared now do you meen the tall spindels woned fit the rim and ore steering arm???..
      Uploaded with ImageShack.us
      California
      Man it's been a while...I'm using a 13" C5 brake kit...can't remember who made it, though. It was cheaper than the SSBC kit, though, which is why I went with it. I'm using 18" E46 M3 wheels. The wheels clear easy, but they limit the turning radius. I need to notch the frame, I just haven't done it due to laziness, lol.
      Matt
      May 2002
      Northern California
      im doing a notch right now....get to it Matt.
      David, getting the caliper to fit was the booger....that set up looks lik it will work with a smaller rim. Perhaps have Bogard can make a hoop that will clear it.
      Netherlands
      MR quik i do know they have been in contact together for the dimentions.also Brake man hase compact callipers!.
      these brakes wil go on a 16x11 rim with 4,75 back spacing for the frond of the 68 bird. what do you meen with a ""Hoop to clear it"". thanks david
      May 2002
      Northern California
      Quote Originally Posted by Roadrage David View Post
      I saw that, those look pretty good. 16X11 /4.75???? Your gonna flare it arn't you?
      With a back space of 4.75 I don't think you will have an issue. Specially with the shape of that caliper. Very compact for a 4 piston.
      Some rim manufacturers will have a different hoop to clear a C5/C6 or larger brake. Or at least know what to do to make them clear.
      Looks good.
      Vince
      Netherlands
      Ok thanks . yes we are going to flare it. the rear as wel 16x13x27..
      anyway feel beter now al parts are alredy orderd only the rims have to be made.
      St George Utah
      no way a 16x11 with 4.75 BS will fit inside the fender of a 68 FB just so you know.
      Blake Foster
      www.speedtechperformance.com
      435-628-4300
      St. George Utah.
      it's always sunny here.
      Netherlands
      Read above Flare as in Fender flares!!!! hahhahahaha
      Belle Plaine, MN
      That's a mighty angry stance. Killer!
      Scott Parkhurst
      Jul 2007
      Los Angeles, CA
      Fronts are GW Upper and Lowers with QA1 coil-overs and AFX Tall Spindle (3/4" drop).
      Rushforth Strutters in 17x8 with 5.00 BS on a 245/45/17 Michelin PS/2 Tire. Brakes are Touring Classics C5 kit with 12.7” rotors. I had to clearance the caliper heat sink fins a bit to make sure everything cleared on a 17" wheel (nothing was hitting just wanted a margin of safety was very close).
      Rears are a bit wider
      Nov 2010
      Minneapolis, MN
      I was considering running C5 brakes with my 17" x 8" Rims with 4.5" BS. (67 Camaro)
      I have not decided if I will use my stock hubs in conjunction with hubs/brackets from Tobin @ 3Kore, or buy ATS spindles.
      Any suggestions? Will a 17" rim clear such a system? Is it worth purchasing the ATS spindles to accompany a Speedtech sub frame?
      It seems as though the C5 Kits from Tobin are more economical that most of the other equivalent aftermarket kits.
      Thanks for your help.
      Bobby
      -67 Camaro in process: Speedtech Track Time Pkg (AFX Spindles, C5 Zo6 brakes, rack, rear torque arm, 9", Ride Tech coils, and a L92/6L80e Swap).
      -2005 Jeep Rubicon Limited LJ, 35"er's, 6" Nth Degree Lift, Hanson Bumpers, 8274 Winch, with a Redbone Coonhound in the backseat.
