      Oct 2007
      orange county, california
      idle fluctuation and engine dying
      The engine is a 95 trans am LT1 backed by a T56. ITs has pretty much full bolt ons and a larger cam/1.6 rockers + tune.
      My issue that ive been having since dropping this engine in my 69 camaro is an idle flucuation issue right after starting. When i first start the car and start to drive it the idle will jump all around when im in nuetral/ clutch in. The idle will drop as low as 500 and jump as high as 1000 RPMs. The biggest issue is that this will sometimes drop low enough to make the engine die.
      I have noticed that this issue is minimal and rarely causes the car to die when its really warm out/summer time. It also lasts a significantly shorter period of time when its a warm day or night.
      When its cold out/ winter time itll take much longer for the idle fluctuation to go away and it will stay on the lower side and die much more often.
      When the fluctuation does finally go away the idle will jump to about 950 to 1000 and stay there. That becomes my idle.... a bit high i think.
      Are there any ideas as to what could cause this? Im thinking due to the sensitivity to temperture that maybe its some kind of temp sensor???
      Ive already cleaned and checked the idle air control and mass airflow sensor.
      "What is each day but a series of conflicts between the easy way and the right way?"
      69 camaro, daytona blue. LS376-495 (Hotcam LS3), TR-6060 6-speed
      Tubular control arms with coilovers
      Nor Cal
      Does it have that POS optispark? Could it be that? I had a 95 Z many years ago and I remember everyone else having the optispark issues... I luckily never did.
      1968 Camaro widebody project
      2004 Mustang LS2
      1964 Continental
      2014 Keezer
      Jacksonville, FL
      Is this the same issue you had back in this post http://www.g-machines.com/forum/show...-HELP&p=651909 back in March? Did you ever contact your tuner or try adjusting to get the correct IAC and TPS settings per the tuner?
      Chris
      1968 Chevy Camaro SS
      LS3/4L70e, DSE suspension
      Jun 2010
      spokane
      Check the voltage to throttle postion sensor when t body closed it should be in the area of .50 volts then open throttle body and watch voltage change it should go up to almost 5.0 volts when fully open . If voltage is below .50 or above .76 volts with tbody closed replace tps sensor also check the pintle in idle air control motor it operates in steps to open and close if carboned up it will cause similar symptoms erratic idle . Also check for vacume leaks spray carb cleaner around any vacume source such as intake manifold and vacume lines and see if idle changes .
      Tim
      Oct 2009
      New Derry, PA
      Is there an inlet air temp (IAT) sensor in addition to (or built into) the MAF? If the IAT signal is false or out of range, the ECU may be trying to compensate. This could explain the difference in behavior with the change in ambient temp.... Just a thought.
