      Dec 2008
      Columbus, IN
      LS1 intake swap worth it ?
      I have a opportunity to trade the intake off my 98 f-body LS1 even up for an intake off a 98 corvette. The corvette intake does not have the EGR behind the thottle body (LS6??). My questions are is this a worthwhile swap or not worth the trouble? Are there any draw backs to this intake on a LS1? Sorry if the answers are obvious. I'm new to the LS engine. Thanks
      '66 Mustang
      '67 FireBird https://www.pro-touring.com/forum/sh...light=firebird
      '68 Barracuda
      '69 Mustang Mach 1
      '97 Mustang Cobra
      '04 Mustang Cobra
      Dec 2009
      St. Louis, MO
      A 98 Corvette would not have the LS6 style intake. That didn't happen until 01, I believe. The swap would not really gain you anything. Now if you do want to get an LS6 intake you can get about 15-20 extra hp out of that swap.
      Tim
      1972 Camaro
      Dunwoody, GA
      correct, the LS6 intake is flat on the bottom and doesn't have the wave like the LS1 intake does. You'll gain only astetics from this swap by getting rid fo the EGR. If you do want to swap to an LS6 intake, that would be worth your time and money. You'll need steam pipe block offs for the rear of the head and an LS6 front crossover pip for the front of the engine along with the intake itself.
      Trey
      ~ Jon Hammond
      Dec 2008
      Columbus, IN
      Thanks for the info guys. I had a feeling that was the case. I'm gonna pass on this trade. Thanks again............Scott
      '66 Mustang
      '68 Barracuda
      '69 Mustang Mach 1
      '97 Mustang Cobra
      '04 Mustang Cobra
      Jan 2010
      Goshen, Ky.
      you could pick up a couple of ponies just because the egr is not in the intake track. You can gain 1-2 by cutting down the egr in the intake.
      Jan 2010
      Goshen, Ky.
      I would look for the a used ls6
      Oct 2006
      McKinney, TX
      If you check out LS1tech you will find tons of info on the LS6 intake swap. Many folks on there swear that the swap gives them 15 more at the wheels. The LS6 intake does flow better than the LS1, but how much is up for debate. check the site-you will get more info than you could ever imagine.
      Confucius says, "Choose a job you love, and you will never have to work a day in your life"
      My build Beast
