    Results 1 to 1 of 1
      austria, where the kangaroos go skiing
      Country Flag: Austria
      slipping clutch?????
      clutch started slowly slipping. at first i thougt i have a power loss on my engine cause i couldnīt barely get the tires spinning. when the clutch was new it roasted the tires easily from 1st all the way to 3rd gear. at the worst point i couldnīt pass a car on highway cruising speed cause the engine revved up but didnīt accelerate. we removed the tranny and found out that there was an oil leak at the rear pan seal and oil went into the bellhousing. we removed everything and soaked/cleaned it with brake cleaner. after the parts went back in it was wayyyy better but after a couple miles the clutch started slipping again. its a tko600 with the 650ft/lbs pro touring clutch kit from keisler. clutch grabs from about half way out and all the gears shift smooth. the release bearing has no pressure on it when the pedal is fully disengaged. any thoughts?flywheel has grinding marks on it, should i get it turned down to smooth it?
      thanks,
      pat
      69 camaro, 418cui p1sc1, ridetech,forgeline, and some more money wasted
