Carb not properly sealed to the intake? Take some carb cleaner and spray around the base of the carb, if the RPMs drop you've found a base gasket leak. Sounds like a loss of vacuum somewhere. Also, what's your initial timing set to. Maybe too low? HTH, Dan
