    Thread: Battery Drain?
      Dec 2009
      Austin, TX
      Battery Drain?
      My 69 Firebird is now showing issues with battery drain if not started with in a couple of days.
      When I got the car it sat for a week between startups, maybe a little longer.
      Over the summer I added Vintage Air w/ 3 knob controller, March Serp Kit with 140 amp alt., Electric fan, AutoMeter electric gauges in a Covan's thunderdash, electric choke, blower motor removed, fixed the broken wire for the sending unit in the gas tank, a new power interstate battery; there is not stereo in the car now (factory AM radio did not work). No additional electrical stuff was added that was not already on the car.
      We had been driving the car daily for 3-4 weeks after getting everything finished up. We then went on a vacation for about a week and the wife went to start the car one day and the battery was dead. When I get home i checked to make sure A/C was in the off position and lights were off.
      I put the charger on the battery for about an hour and she fires right up so we then take her for a drive for a hour with the rpms around 3000 the entire time on the highway (had to go across town to pick up another car). This was Tuesday night and I kept checking the Volt gauge and made sure it was at the 14 mark.
      So this morning I planning to take the bird to work and try to start the car and I get fast clicking with the dash lights flickering with the headlights off and A/C off.
      I have a volt meter to try and find the drain but want to get suggestions of where to start?
      Anyone had this issue after adding something to their car? What was the final issue/solution?
      Ray
      Rustburg, Virginia
      Couple of things to check.....bad diode in the alternator(diodes are like a one-way valve, they only let current travel in one direction), sometimes a dragging starter motor can create a slight drain while sitting....also a slightly shorted cell in a battery can keep it from holding a good charge.
      Trunk lights and things like that are like the refriderator light, you can't see them burning when the door is closed...but you can touch the bulb and it shouldn't be hot if the trunk has been closed for a while.
      Could just be coincidence that this started after the new install, but then again...may have to pull one fuse at a time and check current draw at the battery with a meter to find which circuit the draw is on....
      Dec 2009
      Austin, TX
      I disconnected the negative battery cable from the battery and put a amp meter between the cable and post of the battery.
      It showed .50 draw with a 20A setting on the dial.
      Gave the battery a charge enough to fire right up and the volt gauge in the dash sat just above 14 while driving around; sitting idle at a light it dropped to 14.
      Rustburg, Virginia
      console light, glove box light...couple more items to look for.
      I was hoping others would chime in...I know that I'm forgetting other stuff.
      Oct 2006
      McKinney, TX
      check the parasitic draw thread right below this. There is some good info on how to hunt down a draw.
      Confucius says, "Choose a job you love, and you will never have to work a day in your life"
      My build Beast
      Dec 2009
      Austin, TX
      I found a ground source that some things were connect to. One of those things also happen to be 12 volt off the fuse box under the dash. Got that disconnected and now .02 amp draw at the neg battery post.
