      UTAH
      Alternator brackets Q? .. Difference in dimension
      So I'm fighting an Alternator belt squeal at upper RPM's (about 4600-5400 redline) on my BBC in a 1967 Camaro. Alternator is mounted top of passenger side head (69+ style NOT 67 location), with a CHEAP chrome bracket on top, and the factory mounts for the rest ...
      I already have a tried a HUGE pulley on it (5") too slow it down and that didn't do the trick ...
      Question is between these too aftermarket brackets there is a 3/32" rear spacers dimension difference ???
      .. I'm thinking that the MARCH one would put my belt "slightly" more inline as it look just barely too far forward now
      March:
      http://www.marchperf.com/instruction...nstuctions.pdf
      Billet Spec:
      http://www.billetspecialties.com/assets/pdf/754.pdf
      THOUGHTS ?
      THANKS! ~DaVe
      UTAH
      DaVe
      chirp, chirp, chirp ...
      Ok so does anyone run anything besides stock alternator brackets ?
      ~DaVe
      May 2002
      Northern California
      how is your belt angles and gaps? pictures?
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      UTAH
      Well I don't have pics yet, BUT I do think FLEX maybe the issue as mentioned above ...
      I ended up ordering the SUMMIT brand (cheaper) after talking to their tech line they gave me a confirmation on the 3.25" dimension ...
      http://static.summitracing.com/globa...sum-420102.pdf
      Hopefully we will see how it works by the end of the week
      ~DaVe
      Sep 2002
      San Jose, CA
      The real problem is probably flex. Those chrome cheapie brackets flex a lot when you stress them.
      The best brackets I have found (by far) are Alan Grove
      http://www.alangrovecomponents.com/Catalog.htm
      Just call me Brett
      UTAH
      Well I'm happy this summit bracket and a 7480 belt from checkers and no more belt squeal, now I need a lower RPM module in the MSD as I'm not short shifting for the belt, and the BB doesn't really have the parts to get the 6k chip ;)
      ~DaVe
