    Results 1 to 17 of 17
      Aug 2010
      Los Angeles
      Where to get 700r4
      Hey guys,
      I currently have a 350/350 turbo and have been doing some research on the 700r4. I am not mechanically inclined or have a location to do this swap myself and I had a couple questions.
      First off, and this is embarrassing, how can I tell if my 350 by looking at it is a 2 or 4 bolt? I am totally new to the car world so my apologies.
      I won't be racing this car and it would most likely weekend cruiser/daily driver. However, if I decide to put a little more into the engine down the road I wanna make sure it can handle it. I like the idea of the overdrive which is why I lean towards the 700r4.
      What is the best solution for getting the tranny? Should I find a used one and have it rebuilt or just get a new one from somewhere like Bow Tie Overdrives.
      Thanks in advance gurus!
      Fontana, CA
      I run a level 3 Bowtie Overdrives trans and it lives behind a 542 ft/lb 508 hp 383 sbc. If you are near hesperia they will do the install and pressure setting.
      Rebuilt 700s can be a matter of finding the proper core and then finding a reputable shop with knowledge of making them shift properly.
      Another big consideration is the Torque converter. You want it looser for the higher hp engine down the road, but too loose on a stock or mild engine running round town with highway gears (I am making an assumption here) it doesn't make much sense.
      The whole '2-bolt' '4-bolt' thing is in regards to how many bolts hold the 3 inner Main Crank bearing caps in place. 4 bolt configurations being considered stronger and more capable of handling high HP.
      Nick R.
      Aug 2010
      Los Angeles
      Yeah it looks like Hesperia is a bit too far. I guess my next question is, let's say I have a 2 bolt right now but in the summer I'm gonna do an engine swap to a 4 bolt crate engine. Will I still be able to hook up the 700r4 to it and what would I need to do that. I just don't want to pay for something I'll only have on for a few months and then swap out.
      Also, anyone know of a Los Angeles trans shop?
      Oct 2009
      Sleepy Hollow,IL
      The tranny guy I use sells 700r4's with converter for around $1400. No core charge. He did my t-350 and it has never broke behind 585 injuns -a-twisten.
      1
      Dean@ Drc Transmissions
      179 Randall St, Elk Grove Village, IL 60007 (847) 364-5523
      Everything Under the Sun is Intune
      Chris
      http://www.popularhotrodding.com/fea..._am/index.html
      Aug 2010
      Los Angeles
      Thanks for the info Chris but I'm looking for someone local as I would like to purchase directly and have them do the install.
      Eastern Virginia
      Spacepirate, where are you located?
      Scot
      86 Monte SS
      Aug 2010
      Los Angeles
      Los Angeles, CA
      Phoenix Transmission Products!
      http://www.phoenixtrans.com/
      Greg Ducato is a great guy to deal with!!
      SMSgt Ty Ingle, USAF
      "CF71" - Freedom Bird
      Mar 2010
      San Gabriel Valley CA
      Definetly go with the Bow Tie Overdrives TV Made EZ kit. Worth its weight in gold. BTO makes some good stuff, I have been happy with everything I have bought from them.
      Mike Lara
      Oct 2009
      Sleepy Hollow,IL
      Can't blame you on that one. I also like local.
      Chris
      Socal, Ca
      Try SW Performance transmission out of Huntington Beach. Steve is a great guy to deal with, too. He set up my 700R4 and it runs perfect.
      Fontana, CA
      Quote Originally Posted by spacepirate View Post
      All Gen 1 SBC s use the same bellhousing pattern, so a crate SBC and an original SBC will bolt right up in every way.
      Nick R.
      Aug 2010
      Los Angeles
      Awesome!! Thanks Nick and David.
      Cornettsville, ky
      wouldnt a nice 200-4r be a better swap since it will bolt in perfect
      Aug 2010
      Los Angeles
      I dunno. It seems all of the research points to a 700R4. It wont be my daily driver and its not gonna be put on the strip.
      Papillion, NE
      A buddy bought a 2002R4 from Monster Transmissions, seemed like a good deal, but my buddy deployed a couple times before we could get it in the car. Had problems due to assembly then found parts missing in the speedo drive, Monster not only ignored phone calls but later made promises to send parts and never did.
      Seemed odd,the guy seemed helpful, but then all of a sudden just stopped doing what he said. Made me wonder if they are having $$$ problems.
      I'd steer clear just in case
      70 Mustang - 489 cid FE, KC ported Edelbrock heads, Modified Victor Intake, Mass-flo EFI, Erson valvetrain, Supercomps, TKO-600, 4.10 9 inch.
      71 F-100 4x4 SB 4x4, 461 cid FE stroker, Edelbrock Pro-flo 4 EFI
      13 Ram Laramie 2500 4x4 6.7 diesel - trailer puller
      Cornettsville, ky
      well the 200 is the same size as a th350 has more od and is stronger than a 700
      if i was spending the coin id opt for a built 200
