      El Paso, Texas
      Affordable power trunk release setup
      Here's how I wound up adding a power trunk release to my 65 that is similar to the one from Modo Innovations. I was in a salvage yard sometime back and I wandered the Chevy aisles looking for a solenoid that would fit my 65 Chevelle. I looked at all GM brands and years going back to at least 1960. None of the solenoids came even close to my trunk latch. So I went to the Chrysler aisle, no luck. Imports, same thing. So as a last resort I went to the Ford aisle. As I was about to hit the last isle, I spotted an early 80's Ford Crown Victoria with the trunk ajar. JACKPOT!!! $30 later I was at home with a Dremel ready to go. I placed the 65 latch and the Ford electric latch together and the lower parts matched. The main difference is that the electric latch is a little bit fatter and taller. What I had to do was drop the electric latch in from the top and with the dremel I removed some of the metal around the opening where the original latch drops in. On my 65 it had double metal the further you went out, I guess as a reinforcement so you may run into that. You should only have to trim a little off of that. You don't have to remove a lot, just enough so the latch can fit thru. The original latch had three bolts attaching it, the new one only has two. The trunk lock cylinder rod lined up perfect and fit just fine. As for the lower latch that is bolted onto the trunk floor, I had to trim it just a little for the latch to fit thru. I had to cut off one side of the overhang since the latch is slightly fatter than the original. I'll attach a pic so you all can see what I mean. I believe you have to do the same with the Modo kit. All that is left is to run the wire to a switch or alarm and you are set. It's worked fine for several months now with no problems. I found these solenoids only on Fords. No Lincoln, no Mercury, only Ford Clown Vics, early 80 to mid 80's. If anyone wants one, I did pick up a couple of extras. No markup just pay what I paid for 'em. I figured for those of us on a budget, it's a really affordable way to go. Plus it looks like the solenoid Modo uses on their other kits so it may fit other applications. If anyone has any questions or wants more pics, feel free to email me. Thanks and I hope this helps everyone.
      beaverton oregon
      i just scored on ebay with a 4 solenoid remote locking system for $60 plus shipping. switcher has 6 output channels. you could retro fit remote door locks and control your truck latch remotely also with key pad. then still have 3 more channels to control remote start or whatever you wanted.
      Feb 2010
      Corvallis Montana
      thats a good deal!!! how many lbs are the popers
      beaverton oregon
      15lbs. you could use your stock trunk latch, and just weld an arm off of the connecting bar off the key. plan on putting a door popper set up on the trunk so it will lift free of the latch making it one touch.
      ironically, the set up just showed up at my door a few minutes ago. everything looks good and good quality. it is autoloc.
      with the other channels you could hook up remote power windows too. they had it for $59 opening bid, $240 bin. they have so many auctions though, nobody bids. really is a steal!!
      4 window power set up can be had for $120 shipped also.
