      Aug 2009
      How Much Fuel Flow for 550 HP?
      My fuel system is currently setup for a carb and I have a mechanical fuel pump that will flow 150 GPH at 4.5 psi. I know there are guys running the Holley HP series pumps that flow 150 gph at 16 psi. I was thinking about going with an in-tank electric setup which flows significantly less fuel (65 gph at 45 psi) but at a higher pressure. I was wondering if anyone knows how much efficiency is gained by running a higher pressure pump. For example, would the 65 GPH pump running at 45 psi flow as much fuel THROUGH a -8an system as the 150 gph pump running at 16 psi?
