    Results 1 to 20 of 22
    Thread: backspacing?
      Apr 2008
      Penfield, NY
      backspacing?
      ok Iam getting a conflict of interest here! which pic is the correct way to measure backspacing?
      Sep 2009
      Long Island, NY
      Second one
      Ken
      BirdBoy that would be the second pic you have here is another pic for you for Backspacing
      Jun 2009
      Definitely the second pic. Also consider the tire bulge when sizing your wheels.
      Sarasota, Fl
      The second is correct for measuring backspacing, but the first one could be used to calculate offset (assuming you knew the advertised wheel width). It seems a lot of folks obsess over offset these days when it is in fact the backspacing that is the important thing to know.
      Apr 2008
      Penfield, NY
      Thanks so much guys. I have a friend that has been in the tire business and he swore the first pic was the right way. Ill go with what you guys say and let him know. Thanks again!
      Jan 2009
      Jacksonville Florida
      your friend is wrong, ask him how many times he had people with wheel fitment issues after his calculations.
      Do what's right,not what's easy
      69 Firebird
      71 Cuda
      98 Supra 6speed white APU
      98 Lexus GS400tt widebody
      Elite Custom Body
      Stefan B.
      Apr 2008
      Penfield, NY
      He was quick to agree with what you guys said. He obviously got the wrong info from someone else. I always ask for several opinions..you know everyone has one, but are not always the right one. I feel confident that u guys know your stuff. Thanks again.
      Oct 2010
      Beachwood, NJ
      Converting to disc brakes
      Hi. Does the wheel fitment change when you change drum brakes to disc brakes?
      Oct 2009
      Sleepy Hollow,IL
      Yes and no. Depends on how big a disc brake and the shape and size of the inside of the rim. My stock 15" Ralley 2 wheels do not fit over my rear 12.19" rear disc with 4 piston calipers. My 15" nascar sytle steel wheel with my slicks on will fit.
      Everything Under the Sun is Intune
      Chris
      http://www.popularhotrodding.com/fea..._am/index.html
      San Antonio, TX
      So what's the big deal being off by 1/4" inch, right? ... lol
      Dave
      Oct 2010
      Beachwood, NJ
      Thanks Taman
      Greenwood, SC
      Quote Originally Posted by Taman View Post
      I think Lex is referring to track width changes when converting from drums to discs?
      If so, then yes, it could change it enough to cause some scrub issues if you are already running a wide wheel.... this is assuming that we are concentrating on backspacing (the original subject of this thread).
      JC Scott
      Oct 2009
      Sleepy Hollow,IL
      On rear brakes the disc is not much thicker than the drum.Maybe .050". Both mount flush to the axle flange so track width is not as affected as in the front wheels. What does change is where the caliper mounts. That can force one to run a different back space.
      Chris
      Jan 2009
      Quote Originally Posted by mc84_zz4 View Post
      sometimes 1/4" free space is all there is to work with
      69 Firebird
      71 Cuda
      Elite Custom Body
      Stefan B.
      Mountain Springs, Texas
      Don't you have to deduct a half inch for the lip in the second picture to get backspacing? My memory is a little rusty but I think that is the case. For example, I think a 10 inch rim actually measures 11 inches lip to lip, doesn't it?
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Oct 2005
      Corona, CA
      Second picture is right. If you need help figuring out the BS, feel free to give Jon or myself a call.
      Apr 2007
      Surprise, Az
      That's always been the case with rims I've messed with. It does seam however some manufactures are different, Including there backspacing measurement..The second piCture in a perfect world would be correct, but I dont think everyone supports it. Meaning I've measureD Budnik's and A/R and they seam to have a different back spacing then ordered until I measured inside the lip. Others are on the outside...
      Looking at the first picture the angle rod seams to be the same thickness as the rim lip so measuring it would pretty much yield the same measurement as the second picture...
      I do agree the second picture should be the right way
      1970 NOVA..Ls2/Tko..Speedtech/Chicayne, Alston Glink
      Chuck D.
      Oct 2005
      Corona, CA
      The second pic is the industry standard and the only correct way to measure backspace.
      Quote Originally Posted by strtlegal View Post
      Quote Originally Posted by Justin@DriverzInc View Post
      So you are saying you do not have to deduct 1/2 inch for the lip?
      Thanks.
