      Apr 2010
      mastic beach, ny
      1st gen spring removal question
      hey guys i have a 69 camaro that i want to remove and cut the front springs on. what is the best and easiest way to do so?. and what amount would i need to cut off the spring to drop about 1-2 inches? thanks-derek
      May 2002
      Northern California
      If its you first time I'd rent or buy a center spring compressor. You pull the shock out and drop it down the hole. Thread in a hook device and pull the spring up, then drop the spindle and lower arm.
      At the shop we just put a jack under the lower arm, remove the shock, sway bar and spindle then slowly lower the jack to take pressure off of the spring, then use a pry bar to pop it out of the lower pocket. You just have to be carefull. Also helps to have a lift rack.
      From my experience it is double the amount you remove from the free height of the spring. That also would depend on the spring rating. 1/2-3/4 of a turn should get you there.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Oct 2009
      Amherst, OH
      What does everyone use as "safety" for the spring to NOT fly out and smash your face in?? lol Chains? Ratchet straps?
      I've only ever messed with SLA suspensions like once in all my years as a body man, so I'm a little apprehensive about any dangers involved. I still get nervous when using the wall mount strut compressor we have!
      Josh
      1968 Firebird project thread - https://www.pro-touring.com/threads/...41#post1180941
      May 2002
      Northern California
      just hang a chain through the spring and out the lower shock hole.
      years ago I shot one across out parking lot into the shop truck. Since then I never under estimated the power of sprung. LOL I hear you, some of them spring compressors are sketchy.
      there is more danger going in than coming out...unlike Mongolian Prawns With Hot Bean Sauce.
      Vince
      Apr 2008
      Penfield, NY
      I cut 2 coils and it drop 3 inches. here are before and after pics
      Apr 2010
      mastic beach, ny
      ^ thats exactly what i was looking for! what size tires r those?-dom
