      Feb 2010
      Central NJ
      Retro-Roller Cams
      While my motor is out (and i need to re-seal a few things) I was considering swapping cams...
      A few years ago I put in a 286 (hydrualic) comp cam.. It seems to be working fine, but with alot of talk about low zinc levels in oil and the fact that i really havent driven it enough to know if its starting to fail, is it worth it to go roller?
      My main goals with this motor are longevity and durability... (think long trips and some autocrossing)
      Any input on roller cams, specifically comp cams "retro-roller" setup would be great!
      Thanks in advance,
      Sean
      Mar 2010
      AZ
      As for the cams themselves, they're great, no complainst there. As to whether it would benefit you, can we get pictures of your current lifters and how many miles\years you'd like to put on them once re-built?
      Robert R.
      1988 S10 blazer 5.0L SBC 700R4 body off build.
      1991 S10 Blazer 4.3L too low daily.
      1975 Cutlass Salon currenlty 350/th350
      Stupidity should be painful.
      Sep 2002
      San Jose, CA
      There is really no downside to a roller cam...
      Keep in mind you will probably have to swap the whole valvetrain (springs, retainers, pushrods)
      Hydraulic Roller Cams have effective red line of 6500RPM, but that does not sound like it's a problem here.
      Post your engine combo, we'll make recommendations
      Just call me Brett
      Apr 2008
      Newark, OH, / Concord, NC
      If you already have a decent amount of time on your present cam and it still looks good you should be able to use it with no problems. Anytime you install a flat tappet cam whether it be hydraulic or solid you should use a zinc additive or a high zink oil such as the Brad Penn or similar specialized oil. It sounds as if your kicking around the idea of installing a roller anyway and that is always the safest way to go. John Partrige at Bullet Cams set me up with my solid roller for my first gen small block, I know that everybody reccomends Comp Cams and their stuff is great so you can't go wrong with either.
      Dale
      IF COMMON SENSE WAS COMMON EVERYBODY WOULD HAVE IT
      Feb 2010
      Central NJ
      Thanks for the replys everyone... I guess i'm trying to put some insurance in my motor... my fear is a long drive and wiping the cam at the worst time (as it always happens)
      The setup is as follows:
      REBUILT STOCK bottom end: 2 bolt mains
      64cc World Product Sportman 2 heads (Iron) w/ screw in studs
      Comp Cams (forgot the P#, but can get it) HD valve springs (good up 575 lift, I believe)
      Comp Cams Magnum pushrods (again, no P#, but I can get it)
      Comp Cams Magnum 1.6 stamped roller rockers
      286 Magnum cam (286/286 Dur / 490 lift)
      Performer RPM intake
      Holley 750
      from my estimates its about a 10:1 Comp ratio
      from my research, i'll just need to by the kit with cam/lifters/button/ and possibly longer push rods (i'll call Comp to get that info)
      -Sean
      Sep 2002
      San Jose, CA
      Personally - I've been most impressed with Crower's Hyd Roller cam setups. Very high quality and well engineered.
      Plan on ponying up for a setup of true roller rockers...
      I'm liking Crower Cam 00404 it's got a little more duration but a wider lobe separation than what you're running now. That should spread the power band out a bit and make a little more juice up top
      Just get Crower's matching component kit (84544) and you are set with the springs/pushrods/lifters ect.
      You may need to machine the valve spring seats on those heads as the valve springs are larger in diameter than "stock" GM's
      Just call me Brett
      Mar 2010
      AZ
      That is a LOT more money and effort than he likely needs.
      Upgraded springs and a used flat tappet cam would make me nervous personally. If you have the money, then now would be time to drop a new cam in it, and you may as well get a roller, slightly better power and good insurance. If you would like I should be able to drop your specs into a dyno program in about 24 hours and let you know about Cams. I don't like just about ANY off the shelf cams made today. Too many people take the cam companies advice and ignore the proper ways to build an engine in favor of just throwing in a big cam with too much LCA and are happy when their butt dyno says it's better.
      Your peak HP should be decided by your head choice, then where you get that power, and your torque curve should be decided by your cam. Unless you're fuel injected and your computer requires it, like the LS guys, you don't need more than 112* of LSA and on a 10:1 build with decent heads, you could easily be looking at 109-110.
      Robert R.
      Feb 2010
      Central NJ
      Thanks for all of your help...
      I'll make my decision soon...
      My friends father (built a few engines), thinks I should leave it in... He said if it hasn't flattened by now I should be fine as long as I keep adding Zinc Additives.... I followed all assembly/ break in procedures so I guess i'm just paranoid...
      I may just wait and see how it goes ... since its about $1000+ to go roller....
      Man i can't make up my mind!
      Thanks again!
      -Sean
