    Results 1 to 15 of 15
      Need shorty headers for BBC
      I have a 69 camaro with air ride and a 454. I have regular length headers and they hit once in a while and are getting pretty banged up on the right side. I was thinking of installing shorty headers on my Gen. 6 454. Any suggestions on brands. I also have PS with a AGR steering box.
      1969 Camaro, GM PP HO 454, Procharger D1-SC, 12 bolt rear end, 3:73 gears, 700R4, Borla XS mufflers, X pipe. Ride Tech Air Suspension and Retrotek Speed EFI. AR S200 wheels and Nitto 555. Wilwood 6 piston with Hydratech boost.
      are you in so cal by any chance. if so I can cut and modify them for ya.
      Brett, Campbell Customs
      May 2010
      Orange, CA
      Patriot offers a nice mid length in 1 7/8".
      Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming 'WOW What a Ride!'
      May 2010
      Orange, CA
      These Doug's #D306 should suit your needs. nice fit, heavy wall tubing, 3/8" flanges
      Jun 2002
      Santa Clarita Cal,
      Second that on the Dougs #D306 headers, nice parts!
      RSK68
      Rick Klein
      Aug 2009
      dont waste your money on shortys as they offer hardly any performance gain. just get a nice set of manifolds.
      May 2010
      Orange, CA
      Quote Originally Posted by 317millhand View Post
      The midlength headers as pictured above have been proven many times to out flow the restrictive cast iron standard big block manifolds.
      Tallahassee, FL
      I'm very happy with my Sanderson BB2s. Mine fit great around the ps box and have plenty of ground clearance.
      I tried the Patriots firt and they did not fit around the ps box.
      Aug 2009
      I also understand that lots of folks "port" their manifolds for better flow. I just dont understand why anyone would go through the expense of adding headers if they arent long tube. With all the varieties of headers now there should be one that fits. I tried several on my Chevelle and found the Hedmans to fit well and provide the same amount of ground clearance that manifolds would. They sit my exhaust about 1/8 inch from the transmission crossmember. you cant ask for any better than that.
      Oh yeah. My first response was about shorty headers. I know nothing about midlength headers so I cant comment on that.
      Thanks Jski 67. The sandersons look good. I may look at Dougs also.
      Anybody know if the Dougs D306 will fit around the Power steering box?
      May 2010
      Orange, CA
      Quote Originally Posted by milehigh69 View Post
      They will fit with the factory power steering box, but not the larger quick ratio 825 box.
      Auburn, CA
      Avoid the Patriots....you get what yo pay for!
      Tim Tracy
      cookeville, tennessee
      what is the difference between the stock ps box and a 825 close ratio? I thought all the earlier gm power steering gears had the same external dimensions.
      Oct 2012
      I put the dougs headers pictured above on my 77 TA/502 BBC with Hotchkis tvs , and they worked out great. My hooker long tubes got destroyed after the TVS install, way too low. Hacked a ring out of the front springs to get the rake I wanted.
