Results 1 to 11 of 11
Thread: Looking at EFI
New to Pro-Touring
- Jan 2008
- Watertown NY
- 13
Looking at EFI
I have a 68 camaro with a 427 SBC
It is a dart SHP block 4.125 bore 4.00 stroke,
dart pro1 215 heads
10.5 to 1 comp
Single plane with holley 700cfm DP 2 corner idle
Hyd roller Comp # 12-444-8 grind XR300HR-10
gross lift int .562 ext .580
Duration @ .050 int 248 ext 254
110 lope sep
1 3/4 primary long tube headers
3" pypes ext with X tube and street pro mufflers
TKO600 trans with aluminum flywheel
PVC valve and power brakes
CS130 alt
Mrk XIII electric fan
Timming is set at 12 int and 38 at about 3000rpm with Vac Adv connected to manifold
Dyno numbers with a 850cfm
@3000 270HP 475TQ
@3500 335HP 503TQ
@4000 387HP 508TQ
@4500 444HP 518TQ
@5000 492HP 517TQ
@5500 530HP 506TQ
@6000 547HP 472TQ
@6300 550HP 458TQ
@6500 544HP 440TQ
I have worked with a lean condition just above idle and got it better by opening the idle feed up but it still isn't great and with the carb being a little small for this motor. I have considered EFI to be able to tune it better and maybe make it have better street manours.
1-So how would the Holley HP # 559-810 kit withe 36#injectors work in this application?
2-Would sequential be the way to go?
3-What is the best way to get Cam, Crank sensors, a dual sync or crank wheel
4-How well will the Holley manifold fit the dart pro 1 215 cc heads?
5-Has anyone used a LS1 fuel pump/sump in a first gen camaro?
Thanks Riley
Tags for this Thread
