Thread: FAST Expert Needed - Dist Issues
09-22-2010 #1
- Dec 2005
- 40
Tried getting the motor fired up again after 6 long months of taking a break. I bought an XFI kit from Frank @ Prodigy last year and I'm still #*king around with it trying to get it to work. I got fed up after the distributor module blew up and I threw in the towel for a long time.
So far, I have burned up 2 distributor modules trying to get this damn thing to fire/run. I have been chasing down some interference that is causing the RPM's to spike all over the place when I'm trying to start it. I thought it might be ground related, but since then I have switched over to a 1/0 cable to the starter, and the same for the ground to the water pump bolt. Also added another 1/0 ground to the rear bolt on the cylinder head to the chassis and another smaller ground from the block to the frame. I think that should be enough grounds.
At first the modules work fine. I apply 12v, set the 50 ref angle, and lock down distributor. Easy enough, done. Cam/Crank LED's on the XFI/module are lighting up just fine. However, the points light was not lighting up though on the XFI. I went into the Dashboard and made sure all the parameters were correct, saved to the XFI, and tried again. Now the points lights fired when I tried it again. Strange. I figured I was home free at this point.
Cranked over the motor again and still seeing the huge spikes in RPM all over the damn place. Now the LED's on the module are both lit up, and I'm getting nothing on the XFI for Cam/Crank LED's. WTF...You gotta be $hitting me, wasted again.
I really don't know where to go now other than to throw this POS FAST distributor in the ***** can and go back to a reliable HEI.
I did try to isolate a few things in the process, I unplugged the injector harness, disconnected the negative side of the coil, disconnected the coil wire to the cap,Crank trigger is looped. I thought the plug wires might have been causing the RPM spikes, still no luck. The MSD 6Al I'm using tests out ok by grounding the white wire, but it's very old (10+ years)
This is the same damn reason I stopped working on this POS last year. There was another person that had the same exact issue I had(interesting to note he had an MSD 6al as well). He fixed it by wrapping his FAST harness with foil but I never did hear what was causing his issues.
I have been talking with Brian on EFI101(turbonova). Anyone else have some suggestions??
69 SS396 Camino 540 FAST EFI BBC
http://profile.imageshack.us/user/peetsjunkie/images Check out the latest stuff here!
