    Thread: saginaw 4-speed
      May 2009
      upstate N.Y.
      saginaw 4-speed
      What kind of power and abuse can a saginaw 4 speed handle. I know its not a rock crusher but I have seen friends be pretty rough on these back in the day, of course they were only backing 300ish horsepower smallblock. I guess my question is, that, with a 400hp 350 I'm sure street driving and some autocrossing will be fine but if I sidestep or do a hard launch is the saginaw gonna come apart?
      Loganville, GA
      It may not come apart the first time, but it will eventually, much like a T5 would. Well, the Saginaw might outlast the T5 actually. Sticky tires will kill it quickly. But the good news is Saginaws are plentiful, no need to fix one, just replace. Some of the roundy-round suppliers sell them rather cheap. A Muncie or Super T10 would be a better choice.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
      May 2009
      upstate N.Y.
      As far as sticky tires go, Im runnin 17x11's with sumatumo 315/35/17 tires. I'll probably go to a stickier tire like a bfg kd when I wear those out. I'm building on a tight budget so I'm thinkin I'll make the saginaw work until I can find a t-10 or muncie for the right price.
      USA
      I've seen the Saginaws hold up to some punishment .
      David Sloan used to dragrace an El Camino Big Block and would kill a Saginaw behind it in about 3 weeks..
      If you put over 400 hp and sticky tires , you'll kill them in a short time.
      But , with 350ish hp and street tires , under normal light use , they will last a while ..
      If you just spin the tires behind them and don't have a set of tires that hook-up .
      Or if you are not doing 3800 rpm launches , they will last ok..
      Jeff Tate
      U.S.A.
